Separability of vibrational and rotational motion for diatomics
In summary, the conversation discussed the approximation that the vibrational and rotational motion of a diatomic molecule is separable. The full Hamiltonian for two atoms of masses m1 and m2 can be separated into a center of mass Hamiltonian and one in terms of the reduced mass in the molecular frame. To show that the Hamiltonian is approximately separable, the last term was split into two terms and it was found that the rotational energy can be obtained through first order perturbation theory. This is due to the difference in energy scales between vibrational and rotational transitions, which allows for low coupling strengths.
tomothy
I'd like some help justifying the approximation that the vibrational and rotational motion of a diatomic molecule is separable.
For two atoms of masses m1 and m2 the full hamiltonian is
[itex]H=-\hbar ^2 /2m_1 \nabla _1 ^2 - \hbar^2 /2m_2 \nabla _2 ^2 + V(r-r_0)[/itex]
Where V(r-r0) is the potential energy function, r0 is the equilibrium bond length and r is the atomic separation [itex]r=|\textbf{x} _1- \textbf{x} _2|[/itex]. This is seperable into a centre of mass hamiltonian and one in terms of the reduced mass, in the molecular frame. The hamiltonian in the molecular frame is
[itex]H_\mu = -\hbar ^2 /2\mu \nabla ^2 - V(|\textbf{x}|-r_0)[/itex]
From this point, I'm not sure how to show that the hamiltonian is approximately separable. I tried writing it in terms of the equilibrium displacement [itex]x=r-r_0[/itex] and then by saying in the approximation that [itex]x>>r_0 , x/r_0 \approx 0 [/itex] so in the hamiltonian [itex] r^2=r_0^2(1+x/r_0)^2\approx r_0^2[/itex] but since [itex]r=x+r_0[/itex] is a variable and not a constant of motion, this seems like a dodgy approximation. Any help would be valued greatly!
I would try to split the last term into two terms.
This hamiltonian commutes with J^2 so it is separable into an angular part (the spherical harmonics) and an equation in r. The equation will only in general be solvable for j=0, if it is something like a harmonic potential or a morse potential. So the only way to get the rotational energy out is to throw use first order perturbation theory. So the rotational energy is a first order perturbation or vibrational energy?
Throw away the mathematics for 5 seconds and ask yourself what are the relative transition energies. This is the same reason that we can typically decouple vibrational and electronic transitions through the Born-Oppenheimer approx. Of course there can be ro-vibrational coupling in the same way that B-O fails at conical intersections, but for the most part the two transitions are at such different energy scales that they have low coupling strengths.
Related to Separability of vibrational and rotational motion for diatomics
1. What is the definition of separability of vibrational and rotational motion for diatomics?
The separability of vibrational and rotational motion for diatomics refers to the ability to treat the vibrational and rotational degrees of freedom of a diatomic molecule as independent of each other. This means that the energy of a diatomic molecule can be expressed as the sum of the vibrational energy and rotational energy, and these two types of motion can be analyzed separately.
2. How does the separation of vibrational and rotational motion affect the energy levels of a diatomic molecule?
The separation of vibrational and rotational motion allows for the energy levels of a diatomic molecule to be described by a combination of vibrational and rotational quantum numbers. This results in a more complex energy level structure, with multiple vibrational and rotational states contributing to the overall energy of the molecule.
3. What is the physical significance of the separability of vibrational and rotational motion for diatomics?
The separability of vibrational and rotational motion is important for understanding the behavior of diatomic molecules in various environments, such as in chemical reactions or in the presence of external forces. It also allows for the precise calculation of molecular properties, such as bond lengths and strengths.
4. Are there any exceptions to the separability of vibrational and rotational motion for diatomics?
While the majority of diatomic molecules exhibit the separability of vibrational and rotational motion, there are some exceptions. These include molecules with large differences in their bond lengths or those with significant anharmonicities in their vibrational energy levels.
5. How is the separability of vibrational and rotational motion for diatomics related to the Born-Oppenheimer approximation?
The Born-Oppenheimer approximation is based on the assumption that the vibrational and rotational motions of a diatomic molecule are separable. This allows for the simplification of the molecular wavefunction and the separation of the electronic and nuclear motions. Therefore, the separability of vibrational and rotational motion is a key concept in the Born-Oppenheimer approximation.
