Separable D.E., Partial Fractions
In summary, it seems that Partial Fractions should be used to solve this D.E., but I cannot find an example to go by.
EtherealMonkey
41
[tex]\frac{dP}{dt}=P-P^{2}[/tex]
It seems that Partial Fractions should be used to solve this D.E., but I cannot find an example to go by.
I even tried to rewrite the equation as:
[tex]\frac{d}{dx}Y\left(x\right)=Y\left(x\right)-Y\left(x\right)^{2}[/tex]
But, that isn't helping me either...
Anyone?
Please?
I know this may seem so obvious. And, in fact a great deal of my trouble in D.E. so far can be summarized by my "not seeing the forest for the trees".
So, any hint would probably get me going...
This is what I have done so far...
[tex]P\left(t\right)\frac{d}{dt}=P\left(t\right)-P\left(t\right)^{2}[/tex]
[tex]P\left(t\right)\frac{d}{dt}=P\left(t\right)\left(1-P\left(t\right)\right)[/tex]
[tex]\frac{1}{P\left(t\right)}dP=\left(1-P\left(t\right)\right)dt[/tex]
[tex]\int \frac{1}{P\left(t\right)}dP= \int dt - \int P\left(t\right) dt[/tex]
[tex]\ln \left(P\left(t\right)\right) = t - \int P\left(t\right) dt[/tex]
I see you were able to get the 'y' in your user name!
One comment: you're still using the derivative operator incorrectly: d/dt requires something to the right of it, since it means to take the derivative with respect to t of something.
Now, let's look at your DE.
[tex]\frac{dP}{dt}~=~P~-P^2[/tex]
After separation, you get this.
[tex]\frac{dP}{P - P^2}~=~dt[/tex]
Now integrate both sides. You will want to use partial fractions for the integral on the left side, and should get two terms involving ln|P| and ln|1 - P|. Don't forget you'll need the constant of integration.
Is that enough to get you started?
Yes, thank you very much!
Sorry for the late response, I just got on campus.
Now, got to go take a test, wish me much success!
Thanks again Mark!
FAQ: Separable D.E., Partial Fractions
1. What is a separable differential equation?
A separable differential equation is one in which the dependent variable and its derivative can be separated on opposite sides of the equation. This allows for the equation to be solved by integrating each side separately.
2. How do you solve a separable differential equation?
To solve a separable differential equation, you must first separate the dependent variable and its derivative on opposite sides of the equation. Then, you can integrate each side separately and solve for the constant of integration. Finally, you can substitute the constant back into the equation to obtain the solution.
3. What are partial fractions?
Partial fractions are a method used to decompose a rational function into simpler fractions. This is done by expressing the rational function as a sum of simpler fractions with a common denominator.
4. When are partial fractions used in solving differential equations?
Partial fractions are often used in solving differential equations when the equation contains a rational function. By decomposing the function into simpler fractions, it becomes easier to integrate and solve the equation.
5. What are the steps for solving a differential equation using partial fractions?
The steps for solving a differential equation using partial fractions are as follows:
1. Factor the denominator of the rational function
2. Write the rational function as a sum of simpler fractions with a common denominator
3. Set up equations to solve for the unknown coefficients
4. Solve the equations for the coefficients
5. Substitute the coefficients back into the original equation
6. Integrate each term separately and solve for the constant of integration
7. Substitute the constant back into the equation to obtain the final solution.
