Separating hydrogen from effluent HHO by gravity.
In summary, the conversation discussed the practicality of separating HHO gas from a photovoltaic charged lead-acid battery bank for hydrogen storage. The idea was to collect the gas through tubing and use a manifold and column to separate the hydrogen and oxygen, with the hydrogen being stored for later use. However, it was pointed out that the amount of gas produced by the lead-acid battery may not be enough to be useful. The conversation also touched on the limitations of hydrogen storage and conversion to electrical power. The importance of quantifying the amount of gas produced and the efficacy of separation was emphasized.
Jeff-AC4AQ
I'm would like to learn of the practicality of separating HHO gas released from a photovoltaic charged lead-acid battery bank for hydrogen storage, perhaps by exploiting the substantial difference in density of the two elemental gases.
It occurred to me that were the gas emitted from batteries collected by means of tubing leading to a manifold, and then to a column, the hydrogen will tend to collect at the top of the column and the oxygen will sink to the bottom. Electronic hydrogen detectors near the top of the column would control a servo controlled valve and positive displacement pump, with the concentrated hydrogen passing through a catalytic mesh to strip the remaining oxygen before high-pressure storage.
I believe there must be a reason why this would not achieve the desired results but I'm unable to put my finger on it. Preventing the recombination of the HHO before separation is a must for safety, even though the quantities are small. Use of non-reactive material which does not accumulate static charges will make things unlikely to go bang in the night.
Any thoughts on this would be appreciated, Jeff
Why don't you just run an electrolysis device using a photovoltaic panel and directly capture the H2 and O2 gases at each electrode? That way it's already separated when you capture it.
Likes Bystander
I've considered doing just that with excess energy from the photovoltaic array. However, my objective is to learn whether an energy stream which is usually wasted can be saved for later use, perhaps as one resource among others to bridge the "January Gap" when photovoltaic output is low and electrical demand (mostly from my geothermal heat pump) is high. Also, I recognize the limitations present in hydrogen storage and conversion of hydrogen to electrical power, so this scheme is likely to be of marginal value.
Thanks for your thoughts on this, Jeff
Saving wasted energy is good. But I think you will be disappointed by how little hydrogen is produced by the lead-acid battery.
If you are going to work with engineering ideas, then you must start doing it with numbers, not just principles and theories. Do a little research and find out how long it would take a lead-acid battery to produce 1 m3 of H.
Likes russ_watters
There shouldn't be enough gas produced to be useful. If there is, you need new batteries. :wink:
Likes russ_watters
Thank you both for your responses. As a matter of fact, before considering this scheme I searched online until I was able to find the formula to calculate the quantity of HHO gas emitted by lead-acid cells during a charging cycle. Not too easy to find, but I discovered it in a battery manufacturer's webpage on determining the ventilation capacity needed for rooms where lead-acid batteries are charged. It included the function of gas emission vs. increasing state of charge (low initially and for much of the cycle, becoming high as full charge is approached).
Also, the only aspect of my original question where quantification would be appropriate would be the efficacy of separation, i.e. percentage of gases other than hydrogen in the product. The matter of whether the process volume is 10 mL or 1 cubic meter per day is extraneous.
Thanks again for the advice, de AC4AQ
Them it is also extraneous whether your energy harvesting harvests one joule or one millijoule.
Related to Separating hydrogen from effluent HHO by gravity.
1. How is hydrogen separated from effluent HHO?
Hydrogen can be separated from effluent HHO by using gravity, which involves allowing the mixture to settle and separating the lighter hydrogen gas from the heavier effluent.
2. What is the purpose of separating hydrogen from effluent HHO?
The separation of hydrogen from effluent HHO allows for the isolation and collection of pure hydrogen gas, which can then be used for various applications such as fuel for vehicles or energy production.
3. What equipment is needed for this separation process?
The equipment needed for separating hydrogen from effluent HHO includes a container or tank for the mixture to settle, a valve or outlet for releasing the separated hydrogen gas, and a means of collecting and storing the gas.
4. Are there any safety concerns when separating hydrogen from effluent HHO?
There are potential safety concerns when working with hydrogen gas, which is highly flammable. Proper precautions, such as working in a well-ventilated area and avoiding any sources of ignition, should be taken when separating hydrogen from effluent HHO.
5. Is gravity the only method of separating hydrogen from effluent HHO?
No, there are other methods of separating hydrogen from effluent HHO, such as using membranes, electrolysis, or chemical reactions. However, gravity separation is a simple and commonly used method for this purpose.
9K
  • Atomic and Condensed Matter
  • Other Physics Topics
