Separating vector differential equation into components
In summary, the conversation discusses the component form of the differential equations of motion of a projectile with air resistance proportional to the square of the speed. It is shown that the x component of the velocity can be represented by the equation \dot{x}=\dot{x}_0e^{^-\gamma s}, where s is the distance traveled along the path of motion and \gamma = c_2 / m. The conversation also mentions the difficulty of solving this equation and suggests using the equation -\mu(\frac{dx}{dt})^2=m\frac{dv}{dt} to solve for v.
Dustgil
42
Write down the component form of the differential equations of motion of a projectile if the air resistance is proportional to the square of the speed. Are the equations seperated? Show that the x component of the velocity is given by
[tex]\dot{x}=\dot{x}_0e^{^-\gamma s}[/tex]
where s is the distance the projectile has traveled along the path of motion and [tex]\gamma = c_2 / m[/tex]
2. Homework Equations
[/B]
So, the differential equation in vector form is
[tex]m \frac {d^2r} {dt^2} = -c_2\vec{v}|v| -gk[/tex]
[tex]\frac {d^2r} {dt^2} = -\gamma\sqrt{V_x^2+V_y^2+V_z^2}(V_xi+V_yj+V_zk) -gk[/tex]
so x in particular is:
[tex]\ddot{x}=-\gamma\sqrt{\dot{x}^2+\dot{y}^2+\dot{z}^2}\dot{x}[/tex]
But this isn't separable, making things very difficult. I do think that
[tex]s = \int_a^b|r'(t)|dt = \sqrt{\dot{x}^2+\dot{y}^2+\dot{z}^2}[/tex]
or something very close to that. Yet I'm still not sure how I'm supposed to proceed. Maybe I'm getting something fundamentally wrong in the setup? Something else that's obvious? I'm fairly new to differential equations..
Along x-axis, we have: ##m\ddot{x}=-\mu \dot{x}^2##
Then ##-\mu(\frac{dx}{dt})^2=m\frac{dv}{dt}##
Then ##-\mu v.dx=m. dv##
Solve this equation you will have this result
Likes Dustgil
Thanks, this helped a lot!
FAQ: Separating vector differential equation into components
What is a vector differential equation?
A vector differential equation is an equation that involves vectors and their derivatives. It is used to describe the relationship between multiple variables that are changing over time.
Why do we need to separate vector differential equations into components?
Separating vector differential equations into components makes them easier to solve. It breaks down a complex problem into smaller, more manageable parts, allowing for a more systematic approach to finding a solution.
What is the process for separating a vector differential equation into components?
The process for separating a vector differential equation into components involves breaking down each vector into its individual components, and then solving for each component separately. This is typically done by using vector notation and the rules of vector algebra.
Can a vector differential equation be solved without separating it into components?
Yes, it is possible to solve a vector differential equation without separating it into components. However, this may be more difficult and time-consuming, especially for more complex equations.
What are some practical applications of vector differential equations?
Vector differential equations are used in many fields of science and engineering, including physics, mechanics, and fluid dynamics. They are also used in computer graphics and animation to model and simulate the movement of objects in space.
