Separation of KCl from potassium chromium(III) PDTA
  • Thread starter Thread starter Mayhem
    Kcl Separation
The discussion centers on the challenges of separating a coordination complex that produces KCl as a byproduct. Both the complex and KCl are soluble in similar solvents, complicating separation efforts. The organic ligand PDTA shows limited solubility in polar organic solvents, hindering its use for separation. Concerns are raised about the potential degradation of the complex if protation is attempted. The literature lacks straightforward separation methods, and attempts to displace the complex's cation with an organic cation, such as methyltetraammonium chloride, are uncertain. Additionally, the silver salt of potassium chromium PDTA is noted to be insoluble, rendering AgNO3 displacement ineffective. Alternative syntheses that do not produce KCl as a byproduct are referenced, suggesting that crystallization may favor one substance over the other despite their solubility in the same solvents.
Mayhem
The mentioned coordination complex has been prepared where KCl is a significant byproduct. The salt and the complex appear to be readily soluble in the same solvents. Despite the organic ligand (PDTA), it is not soluble in polar organic solvents, at least to a degree where it can be used for separation. Protation is most likely not possible without degrading the complex.
I can't find any literature that puports a simple separation method. I thought that perhaps the complex could have its cation displaced by an organic cation (an methyltetraammonium chloride, for example), which is also water soluble. Not sure if this would work.
Literature shows that the silver salt of potassium chromium PDTA is also insoluble[1], so a simple AgNO3 displacement also wouldn't work.
Any ideas?
Chemistry news on Phys.org
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
