Seperable Equations using a substitution for a differential equation
In summary, the given differential equation is not separable, but by using the substitution u=y/x, a new separable differential equation involving x and u can be obtained. The original differential equation can then be solved by using this change of variable method. After substituting y=ux and y'=u'x+u, the differential equation is simplified and can be solved to find the solution for the original equation.
laura_a
66
The d.e
y' = (y+2x)/(y-2x)
is NOT seperable, but if you use a substitution then you obtain a new d.e involving x and u, then the new d.e is seperable... Solve the original d.e by using this change of variable method
I'm going to use the substitution that u=y/x in the form y=ux
y' = (y+2x)/(y-2x)
let y=ux
then
y' = (ux+2x)/(ux-2x)
y'(ux-2x) - (ux+2x) = 0 <--- thus it is seperable
So I can say
d/dx((ux^2)/2 - x^2) - d/dx((ux^2/2) + x^2) = 0
Putting it all together
d/dx[(ux^2)/2 - x^2 - (ux^2)/2 - x^2] = 0
d/dx (-2x^2) = 0
Well that is where I am stuck, how do I solve it from there and what am I trying to get because I've changed the d.e so I'm not sure how the answer from the new d.e will help me find a solution to the original one?
If you are going to substitute y=ux then you also need to substitute y'=(ux)'=u'x+u. That will change the differential equation for y into one for u. You shouldn't have a y' hanging around after the substitution.
FAQ: Seperable Equations using a substitution for a differential equation
What is a separable equation?
A separable equation is a type of differential equation that can be written in the form of dy/dx = f(x)g(y), where f(x) and g(y) are functions of x and y, respectively.
What is the purpose of using substitution in solving separable equations?
Substitution allows us to transform a separable equation into a simpler form that is easier to integrate. This makes it possible to find the solution to the equation.
How do you solve a separable equation using substitution?
To solve a separable equation using substitution, we first identify the variables that are separable. Then, we substitute one variable with a new variable, usually u, and solve for u. After that, we use the inverse substitution to replace u with the original variable and obtain the solution.
Are there any limitations to using substitution for solving separable equations?
Yes, there are some limitations to using substitution for solving separable equations. In some cases, it may not be possible to find a suitable substitution that simplifies the equation. In addition, the solution obtained through substitution may not be valid for the entire domain of the original equation.
Can you provide an example of solving a separable equation using substitution?
Sure, let's take the separable equation dy/dx = 2xy. First, we identify the variables that are separable, which are x and y. Then, we substitute u = x2 and solve for u, which gives us du/dx = 2x. Using the inverse substitution, we replace u with x2 and obtain the solution y = Cx2, where C is a constant of integration.
