MHB Sequence Challenge: Proving Periodicity of $\left\{x_n\right\}$ (Mod 11)
The sequence defined by the recurrence relation $x_{n+3} \equiv \frac{1}{3}(x_{n+2}+x_{n+1}+x_n)$ (mod $11$) is shown to be either constant or periodic with a period of 10. This periodicity arises from the properties of modular arithmetic and the specific structure of the recurrence relation. The discussion emphasizes the importance of analyzing the initial conditions and their influence on the sequence's behavior. Participants highlight the mathematical reasoning behind the periodicity and the implications for sequences defined under similar conditions. The findings contribute to a deeper understanding of recurrence relations in modular systems.
lfdahl
MHB
Let the sequence $\left\{x_n\right\}$ of integers (modulo $11$) be defined by the recurrence
relation:
$x_{n+3} \equiv \frac{1}{3}(x_{n+2}+x_{n+1}+x_n)$ (mod $11$), for $n=1,2,..$
Show, that every such sequence $\left\{x_n\right\}$ is either constant or periodic with period $10$.
Mathematics news on Phys.org
relation:
Since we are working modulo $11$, I understand that $\frac{1}{3}$ means $4$.
This is a linear recurrence relation, whose characteristic polynomial is:
$$x^3 - 4x^2 - 4x - 4$$
Modulo $11$, this polynomial factors as:
$$(x-1)(x-6)(x-8)$$
and this means that the general solution is:
$$x_n = A(1)^n + B(6)^n + C(8)^n\pmod{11}$$
where the constants depend on the initial terms. If $B=C=0$, the sequence is constant; otherwise, since both $6$ and $8$ have multiplicative order $10$ modulo $11$, the sequence has period $10$.
$$(x-1)(x-6)(x-8)$$
Thankyou, castor28!, for your sharp minded contribution and participation, which is highly appreciated!(Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
19K
