Sequence diverges or converges
  • Thread starter fadi_nzr
  • Tags
    Sequence
In summary, a sequence that converges is $(-1)^{n+1} a_n + 3$, while a sequence that diverges is $(-1)^n+1 a_n + 3$.
fadi_nzr
Question 1
write the first 4 terms in the sequence defined by a 1 = -2, a n+1 = an/n!
this what I tried
a2 = -2/1
a3 = -2/2
a4 = -1/6
Question 2
determine the following sequences converges or diverges
1- an = sqrt(n^2 -3 )/ 5th rt(n^2)
what I would try is to divide both top and bottom by n^2 but here doesn't work that
way because the denominator is 5th rt
2- a1 = 3, an+1 = (-1)^n+1 an + 3
a2 = 6
a3 = -3
but the ans would be ( 3,0,3,0,3,0)
fadi_nzr said:
Question 1
this what I tried
a2 = -2/1
a3 = -2/2
a4 = -1/6
Looks fine to me.
Question 2
When ##n## is large, ##\sqrt{n^2 - 3}## is nearly the same as ##\sqrt{n^2}##. So you can use ##\sqrt{n^2}## instead of ##\sqrt{n^2 - 3}## to determine whether the sequence converges or not. Then you can make the argument more precise by comparing ##\sqrt{n^2 - 3}## with an appropriate sequence. (Hint: try comparing it with ##\sqrt{n^2}/2##.)
a2 = 6
a3 = -3
OK, so what can you conclude? Does the sequence converge?
question 2
A-
actually this section was before the comparison theorem so let's assume we can't compare it for now
what is the other way B-it diverges but I don't know how to come up with these values as my values differ ( 3,0,3,0,3,0)
fadi_nzr said:
question 2
A-
OK, try simplifying: ##\sqrt{n^2 - 3}/\sqrt[5]{n^2} = (n^2 - 3)^{1/2}n^{-2/5} = (n^2 - 3)^{1/2}(n^{-4/5})^{1/2} = ?##
Check your values of ##(-1)^{n+1}##. This is ##-1## when ##n## is even, and ##+1## when ##n## is odd. I suspect you have it reversed.
for part A, now it looks complicated to me than before what my prof did is
moving the bottom to the numerator and you get infinity
for part B I still unable to get ( 3,0,3,0,3,0)
Can you show what you mean by this?
Let's go back to the definition:
##a_1 = 3, a_{n+1} = (-1)^{n+1} a_n + 3##
To get ##a_2## we plug in ##n=1##: this gives us ##a_2 = (-1)^2 a_1 + 3 = (1)(3) + 3 = 6##. So already this is different from your ##3,0,3,0,...##.
( 3,0,3,0,3,0) is my professor answer to this part
but as you see we are not getting close to that
Let's go back to the definition:$$
a_1 = 3, a_{n+1} = (-1)^{n+1} a_n + 3$$
I'm guessing there is a typo somewhere and the recursion is supposed to be$$
a_1 = 3, a_{n+1} = (-1)^{n} a_n + 3$$
FAQ: Sequence diverges or converges
What is sequence divergence and convergence?
Sequence divergence and convergence are concepts in mathematics that describe the behavior of a sequence of numbers. A sequence converges if its terms approach a single value as the sequence progresses. A sequence diverges if its terms do not approach a single value as the sequence progresses.
How do you determine if a sequence converges or diverges?
To determine if a sequence converges, you can look at the limit of the sequence. If the limit exists and is a finite number, then the sequence converges. If the limit does not exist or is infinite, then the sequence diverges.
What is the difference between absolute and conditional convergence?
Absolute convergence refers to a sequence that converges regardless of the order in which the terms are added. Conditional convergence refers to a sequence that only converges when the terms are added in a specific order.
Can a sequence both converge and diverge?
No, a sequence cannot both converge and diverge. It must be one or the other.
What are some real-life applications of sequence convergence and divergence?
Sequence convergence and divergence have many applications in fields such as physics, engineering, and economics. For example, in physics, the concept of convergence and divergence is used to study the behavior of infinite series. In economics, it is used to analyze the stability of financial systems.
