MHB Sequence of Positive Integers Challenge
The sequence of positive integers defined by the recurrence relation a_n = a_{n-1}^2 + a_{n-2}^2 + a_{n-3}^2 for n ≥ 3 cannot have a term equal to 1997 for k ≥ 4. If a_k = 1997, it leads to a contradiction when analyzing the values of a_{k-1}, a_{k-2}, and a_{k-3}. The maximum possible values for these terms, constrained by the properties of squares, indicate that they must be less than or equal to 6. The only valid combination of squares that sums to 44 is 6^2 + 2^2 + 2^2, which does not yield 1997 in the required form. Therefore, 1997 can only occur at k ≤ 3, confirming the initial claim.
anemone
MHB
POTW Director
Consider the sequence of positive integers which satisfies $$a_n=a_{n-1}^2+a_{n-2}^2+a_{n-3}^2$$ for all $n \ge 3$.
Prove that if $a_k=1997$, then $k \le 3$.
Mathematics news on Phys.org
[sp]The statement of the problem implies that the first three terms $a_0$, $a_1$, $a_2$ can be chosen arbitrarily, and the rest of the sequence is then determined by the given relation.
Suppose (to get a contradiction) that $a_k = 1997$ for some $k\geqslant4$. Let $x=a_{k-4}$, $y=a_{k-3}$, $z=a_{k-2}$. Then $a_{k-1} = x^2 + y^2 + z^2$, and $1997 = y^2 + z^2 + (x^2+y^2+z^2)^2$. Since $1997 < 45^2$, it follows that $x^2 + y^2 + z^2 \leqslant 44$, and since $44<7^2$ it follows that each of $x$, $y$, $z$ must be at most $6$. Thus $(x^2+y^2+z^2)^2 = 1997 - y^2 - z^2 \geqslant 1997 - 6^2 - 6^2 = 1925 >43^2$, and it follows that $x^2+y^2+z^2 >43$. Thus the only possibility is that $x^2+y^2+z^2 = 44$. But the only way to express $44$ as the sum of three squares is $44 = 6^2+2^2 + 2^2$, and neither of the sums $2^2 + 2^2 + 44^2$, $2^2 + 6^2 + 44^2$ is equal to $1997$ (obviously, since both those sums will be even). Therefore $1997$ cannot be equal to $a_k$ for any $k>3$.
In fact, it is possible to get $1997 = a_3$, for example if $a_0 = 5$, $a_1 = 6$, $a_2 = 44$, then $a_3 = 25 + 36 + 1936 = 1997$.[/sp]
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
