Sequential Stern Gerlech experiment
The discussion revolves around the Sequential Stern-Gerlach experiment and the behavior of angular momentum states when passing through magnetic fields. There is confusion about why a beam with $m_l = 1$ should split into three beams with equal probabilities for $m_l = -1, 0, 1$ when passing through the second SG magnet aligned along the z-axis. Participants emphasize the importance of determining the eigenstates of the $L_x$ operator to understand the relationship between different angular momentum states. The conversation highlights the need for mathematical validation of intuitive guesses regarding the outcomes of measurements related to angular momentum. Ultimately, the focus is on understanding how to calculate probability amplitudes and outcomes for measurements of angular momentum in different orientations.
Rayan
A beam of atoms with ##l=1## (##s= 0##) is traveling along the y-axis and passes through a Stern-Gerlach magnet A with its (mean) magnetic field along the x-axis. The emerging beam with ##m_x= 1## is separated from the other two beams. (The eigenvalue of ##L_x## for the atoms in this beam is ##\hbar m_x = \hbar##). The beam is then passed through a second Stern-Gerlach magnet with the magnetic field along the z-axis. Into how many beams is the beam further split and what the relative number of atoms in each beam? What would be the result if the ##m_x= 0## beam instead passed through a second magnet with the magnetic field along the z_axis?
So I thought that when the $m_l = 1$ beam passes through the second SG-magnet, it should split into 3 different beams with equal probability corresponding to $ m_l = -1 , 0 , 1 $ since the field here is aligned along z-axis and hence independent of the x-axis splitting.
And I thought that the same should happen if the $m_x=0$ beam passes through the second magnet? but I'm not as sure here!
and then there is a hint that says I should determine the eigenstates of the $L_x$ operator first! But I don't get why? Any advice?
That's effectively a guess. It's a good hint to check your guess by looking precisely at how the eigenstates for a spin-1 particle about the x-y-z axes relate to each other.
So you're not just guessing what the answers are. It's okay use your intuition to make an educated guess what the answer should be, but you still need to do the actual math to make a convincing argument.
Let ##| L_z, m_z \rangle## denote an eigenstate of the ##L_z## operator which has eigenvalue ##m_z \hbar##. What are the possible values of ##m_z##?
Let ##| L_x, m_x \rangle## denote an eigenstate of the ##L_x## operator which has eigenvalue ##m_x \hbar##. What are the possible values of ##m_x##?
Suppose the angular momentum state of the particle is known to be ##| L_x, m_x \rangle##. If a measurement of the z-component of angular momentum is made on this particle, what are the possible outcomes of the measurement?
Using the notation ##| L_x, m_x \rangle## and ##\langle L_z, m_z |##, how would you construct an expression for the probability amplitude that the measurement will yield the outcome ##m_z \hbar##?
How do you obtain the probability that the outcome will be ##m_z \hbar##?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
