iamjon.smith
- 117
- 3
Ok guys, I am working on a simple serialize/deserialize project. A user interface takes the following input:
A Department ID (INT), A Department Name (String), and Three Employees (ArrayList) that have a Name, Department, and Salary. Once the Three employees are entered, the Department can be submitted with a button. When the submit button is clicked, the Department information should be displayed in the Text area.
I am writing the Employee object to the console, and to the text area to show the employee is being created, but when the object is retrieved from the file, I seem to have missed something.
The data is passed into a department object, saved to a file, retrieved from that file, and displayed in a text area. I seem to be retrieving just a memory reference instead of the actual file. I have included the code as follows:
IDE: Netbeans 8.0.2
Language: JAVA
Employee Class:
Department Class:
Interface class/ Test Class
Actual Output: SerializeObject.Department@4e2acbe3
Desired Output:
Employee [firstName = James, title = Dev, department = iOS Dev, salary = 234234.0]
Employee [firstName = Steve, title = Dev, department = iOS Dev, salary = 23423.0]
Employee [firstName = Jon, title = Dev, department = iOS Dev, salary = 34234.0]
IDE: Netbeans 8.0.2
Language: JAVA
Employee Class:
Java:
* To change this license header, choose License Headers in Project Properties.
* To change this template file, choose Tools | Templates
* and open the template in the editor.
package SerializeObject;
import java.io.Serializable;
* @author Jonathan
public class Employee implements Serializable {
private String Name;
private String title;
private String department;
private double salary;
// stupid example for transient
private final transient Thread myThread;
public Employee(String Name, String title, String department, double salary) {
this.Name = Name;
this.title = title;
this.department = department;
this.salary = salary;
this.myThread = new Thread();
public String getName() {
return Name;
public String getTitle(){
return title;
public void setTitle(String Title){
this.title = Title;
public String getDepartment(){
return department;
public void setDepartment(String Department){
this.department = Department;
public double getSalary(){
return salary;
public void setSalary(double Salary){
this.salary = Salary;
} @Override
public String toString() {
return "Employee [firstName = " + Name + ", title = " + title + ", department = " + department + ", salary = " + salary + "]";
Department Class:
Code:
import java.util.ArrayList;
* @author Jonathan
public class Department implements Serializable {
private int deptID;
private String deptName;
private ArrayList<Employee> empArray;
public Department(int deptID, String deptName, ArrayList empArray) {
this.deptID = deptID;
this.deptName = deptName;
public int getDeptID() {
return deptID;
public void setDeptID(int deptID) {
public String getDeptName() {
return deptName;
public void setDeptName(String deptName) {
public ArrayList getEmpArray(){
return empArray;
public void setArrayList(ArrayList empArray){
this.empArray = empArray;
Java:
package serializationexample;
import SerializeObject.*;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.ObjectInputStream;
import java.io.ObjectOutputStream;
* @author Jonathan
public class SerializeInterface extends javax.swing.JFrame {
ArrayList empArray = new ArrayList<>();
* Creates new form SerializeInterface
public SerializeInterface() {
initComponents();
submitDeptButton.setEnabled(false);
* This method is called from within the constructor to initialize the form.
* WARNING: Do NOT modify this code. The content of this method is always
* regenerated by the Form Editor.
@SuppressWarnings("unchecked")
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
jInternalFrame1 = new javax.swing.JInternalFrame();
jScrollPane1 = new javax.swing.JScrollPane();
displayTA = new javax.swing.JTextArea();
deptLabel = new javax.swing.JLabel();
deptTF = new javax.swing.JTextField();
deptIDLabel = new javax.swing.JLabel();
deptIDTF = new javax.swing.JTextField();
jPanel1 = new javax.swing.JPanel();
empNameLabel = new javax.swing.JLabel();
empNameTF = new javax.swing.JTextField();
empNameLabel1 = new javax.swing.JLabel();
empTitleTF = new javax.swing.JTextField();
empNameLabel2 = new javax.swing.JLabel();
empSalaryTF = new javax.swing.JTextField();
addEmpButton = new javax.swing.JButton();
jLabel1 = new javax.swing.JLabel();
submitDeptButton = new javax.swing.JButton();
exitButton = new javax.swing.JButton();
jInternalFrame1.setVisible(true);
javax.swing.GroupLayout jInternalFrame1Layout = new javax.swing.GroupLayout(jInternalFrame1.getContentPane());
jInternalFrame1.getContentPane().setLayout(jInternalFrame1Layout);
jInternalFrame1Layout.setHorizontalGroup(
jInternalFrame1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGap(0, 0, Short.MAX_VALUE)
jInternalFrame1Layout.setVerticalGroup(
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
setTitle("Department Interface");
displayTA.setColumns(20);
displayTA.setRows(5);
jScrollPane1.setViewportView(displayTA);
deptLabel.setText("Department Name");
deptIDLabel.setText("Department ID");
jPanel1.setName("Employee"); // NOI18N
empNameLabel.setText("Employee Name");
empNameLabel1.setText("Employee Title");
empNameLabel2.setText("Employee Salary");
addEmpButton.setText("Add Employee 1");
addEmpButton.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
addEmpButtonActionPerformed(evt);
jLabel1.setText("Employee Data");
javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
jPanel1.setLayout(jPanel1Layout);
jPanel1Layout.setHorizontalGroup(
jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
.addContainerGap()
.addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addComponent(empNameLabel)
.addComponent(empNameLabel1, javax.swing.GroupLayout.PREFERRED_SIZE, 92, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(empNameLabel2))
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addComponent(empTitleTF, javax.swing.GroupLayout.PREFERRED_SIZE, 164, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(empNameTF, javax.swing.GroupLayout.PREFERRED_SIZE, 164, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(empSalaryTF, javax.swing.GroupLayout.PREFERRED_SIZE, 164, javax.swing.GroupLayout.PREFERRED_SIZE))
.addGap(21, 21, 21))
.addGroup(jPanel1Layout.createSequentialGroup()
.addGap(138, 138, 138)
.addComponent(addEmpButton)
.addComponent(jLabel1, javax.swing.GroupLayout.PREFERRED_SIZE, 139, javax.swing.GroupLayout.PREFERRED_SIZE))
.addContainerGap(javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
jPanel1Layout.setVerticalGroup(
.addComponent(jLabel1)
.addGap(3, 3, 3)
.addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(empNameTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(empNameLabel))
.addGap(18, 18, 18)
.addComponent(empNameLabel1)
.addComponent(empTitleTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.UNRELATED)
.addComponent(empSalaryTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 18, Short.MAX_VALUE)
.addContainerGap())
submitDeptButton.setText("Submit Department");
submitDeptButton.addActionListener(new java.awt.event.ActionListener() {
submitDeptButtonActionPerformed(evt);
exitButton.setText("Exit");
exitButton.addActionListener(new java.awt.event.ActionListener() {
exitButtonActionPerformed(evt);
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup()
.addGap(31, 31, 31)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
.addComponent(deptIDLabel, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addComponent(deptLabel, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 153, Short.MAX_VALUE)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addComponent(deptTF, javax.swing.GroupLayout.Alignment.TRAILING, javax.swing.GroupLayout.PREFERRED_SIZE, 167, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(deptIDTF, javax.swing.GroupLayout.Alignment.TRAILING, javax.swing.GroupLayout.PREFERRED_SIZE, 167, javax.swing.GroupLayout.PREFERRED_SIZE))
.addGap(29, 29, 29))
.addGroup(layout.createSequentialGroup()
.addContainerGap()
.addComponent(jPanel1, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addContainerGap())
.addContainerGap()
.addComponent(jScrollPane1)
.addContainerGap())
.addGap(24, 24, 24)
.addComponent(submitDeptButton)
.addComponent(exitButton, javax.swing.GroupLayout.PREFERRED_SIZE, 141, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(41, 41, 41))
layout.setVerticalGroup(
.addContainerGap()
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(deptIDLabel)
.addComponent(deptIDTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
.addComponent(deptLabel)
.addComponent(deptTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
.addGap(18, 18, 18)
.addComponent(jPanel1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(35, 35, 35)
.addComponent(exitButton))
.addGap(22, 22, 22)
.addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 134, javax.swing.GroupLayout.PREFERRED_SIZE)
pack();
}// </editor-fold>
private void addEmpButtonActionPerformed(java.awt.event.ActionEvent evt) {
// TODO add your handling code here:
switch (addEmpButton.getText()) {
case "Add Employee 1":
String empName = empNameTF.getText();
String empTitle = empTitleTF.getText();
String empDept = deptTF.getText();
int empSalary = Integer.parseInt(empSalaryTF.getText());
Employee employee = new Employee(empName, empTitle, empDept, empSalary);
empArray.add(employee);
addEmpButton.setText("Add Employee 2");
empNameTF.setText("");
empTitleTF.setText("");
empSalaryTF.setText("");
System.out.println(employee);
displayTA.setText(employee + "\n");
empNameTF.requestFocus();
break;
case "Add Employee 2":
addEmpButton.setText("Add Employee 3");
break;
case "Add Employee 3":
addEmpButton.setEnabled(false);
submitDeptButton.setEnabled(true);
submitDeptButton.requestFocus();
break;
private void submitDeptButtonActionPerformed(java.awt.event.ActionEvent evt) {
String filename = "C:\\Users\\Jonathan\\Desktop\\NuTech Training\\Department.sav";
Department d = new Department(Integer.parseInt(deptIDTF.getText()), deptTF.getText(), empArray);
// save the object to file
try {
FileOutputStream fos = new FileOutputStream(filename);
ObjectOutputStream out = new ObjectOutputStream(fos);
out.writeObject(d);
out.flush();
out.close();
} catch (Exception ex) {
ex.printStackTrace();
// read the object from file
FileInputStream fis;
ObjectInputStream in;
try {
fis = new FileInputStream(filename);
in = new ObjectInputStream(fis);
d = (Department)in.readObject();
System.out.println(d);
displayTA.setText(d.toString());
in.close();
fis.close();
} catch (IOException | ClassNotFoundException ex) {
// for(Object empObject : empArray){
// System.out.println(empObject.toString());
// displayTA.setText(empObject.toString());
private void exitButtonActionPerformed(java.awt.event.ActionEvent evt) {
System.exit(0);
* @param args the command line arguments
public static void main(String args[]) {
/* Set the Nimbus look and feel */
//<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
/* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
* For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
try {
for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
if ("Nimbus".equals(info.getName())) {
javax.swing.UIManager.setLookAndFeel(info.getClassName());
break;
} catch (ClassNotFoundException ex) {
java.util.logging.Logger.getLogger(SerializeInterface.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
} catch (InstantiationException ex) {
} catch (IllegalAccessException ex) {
} catch (javax.swing.UnsupportedLookAndFeelException ex) {
//</editor-fold>
/* Create and display the form */
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new SerializeInterface().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JButton addEmpButton;
private javax.swing.JLabel deptIDLabel;
private javax.swing.JTextField deptIDTF;
private javax.swing.JLabel deptLabel;
private javax.swing.JTextField deptTF;
private javax.swing.JTextArea displayTA;
private javax.swing.JLabel empNameLabel;
private javax.swing.JLabel empNameLabel1;
private javax.swing.JLabel empNameLabel2;
private javax.swing.JTextField empNameTF;
private javax.swing.JTextField empSalaryTF;
private javax.swing.JTextField empTitleTF;
private javax.swing.JButton exitButton;
private javax.swing.JInternalFrame jInternalFrame1;
private javax.swing.JLabel jLabel1;
private javax.swing.JPanel jPanel1;
private javax.swing.JScrollPane jScrollPane1;
private javax.swing.JButton submitDeptButton;
// End of variables declaration
Desired Output:
