Serially joined & vertically hanged springs with a weight in between
In summary, the weight of mass between springs A and B causes displacement x in the direction of the + sign.
fuzzyorama
Three springs, A (spring constant k), B (spring constant 2k) and C (spring constant 4k) are serially joined and are vertically hanged from a ceiling with spring A at the top, spring B in the middle & spring C at the bottom. All three have the same relaxed length of L. The bottom end of spring C is then tied(?) to a table which is tall enough that all three springs are in their relaxed length (the distance between the ceiling & the table's surface is 3L).
If a weight of mass M is put between spring A and spring B, what is
1. the displacement, x of springs B and C,
2. the force, F applied on the spots where springs A and C are tied to (ceiling & table surface)?
Gravitational force is g, no specific numbers. All springs are massless.
mg = -kx
F = mg
Displacement of spring B
mg = 2kx'
x' = mg/2k
Displacement of spring C
mg = -4kx"
2kx' = -4kx"
x" = -x'/2
Wow, I honestly don't know where I'm going with this.
Welcome to Physics Forums.
You're on the right lines with your attempt, but you can't consider each spring individually. Since the two lower springs (B&C) are connected you must consider them together, notice how the question only asks for a single displacement (x) for both springs.
So, the first step is to find the effective spring constant for the combined springs B & C.
Thank you. Oh?! OK so
kBC = (2k*4k)/(2k+4k) = 4k/3
mg = -kBCx
mg = -(4k/3)*x
and
x = -(3mg/4k)
Is this correct? I kinda have a pretty good feeling about this:) If it is, I'm guessing the force on the table's surface is
F = -kBCx = -(4k/3)*(-3mg/4k) = mg ?
Again, you have the right idea, but it's not quite correct. Take a look http://scienceworld.wolfram.com/physics/SpringsTwoSpringsinSeries.html" for information on how to find the effective spring constant for two springs in series.
Err, I'm sorry.. could you be more specific?
If the effective spring constant for springs B and C is
keff = ([tex]\frac{1}{k_{B}}[/tex] + [tex]\frac{1}{k_{C}}[/tex])[tex]^{-1}[/tex]
and kB = 2k, kC = 4k, then
keff = ([tex]\frac{1}{2k}[/tex] + [tex]\frac{1}{4k}[/tex])[tex]^{-1}[/tex] = ([tex]\frac{2k+4k}{2k*4k}[/tex])[tex]^{-1}[/tex] = [tex]\frac{8k^{2}}{6k}[/tex]
so eventually it will be keff = [tex]\frac{4k}{3}[/tex], right?
I'm terribly sorry, I misread your post - I though that you have 3k/4. Apologies.
fuzzyorama said:
mg = -kBCx
Does spring A not exert a force on the mass ...? :wink:
Heh no problem yo :cool:
With spring A taken into account, I can write it as Mg + kAxA = -kBCx
... or can't I?
Because kA = k, and kBC = 4k/3,
Mg + kx = -4kx/3
(skipped)
x = -[tex]\frac{3kMg}{7}[/tex]
I'm getting confused with the + - signs :confused:
... or can't I?
Mg + kx = -4kx/3
(skipped)
You're almost there, but there's a little mistake going from the previous line to the final line.
You're signs are fine. If you're unsure you can do a quick sanity check. If you look at you're original expression:
And consider a positive displacement, then the two forces from the springs will be acting in the same direction as the weight of the mass, as it should be. This also shows that your answer should be negative, since if the displacement were positive, all the three forces would be acting in the same direction and no equilibrium state would be possible.
Oh no I failed at the maths again. How about this?
[tex] x = -\frac{3Mg}{7k} [/tex]
I can latex!
I can latex!
Looks good to me :approve:
FAQ: Serially joined & vertically hanged springs with a weight in between
What is the purpose of serially joined and vertically hanged springs with a weight in between?
The purpose of this setup is to create a spring system that can store and release energy in a controlled way. The weight in between the springs adds tension and allows for a more complex motion.
How does the weight affect the motion of the springs?
The weight adds tension to the springs, causing them to stretch and store potential energy. When released, the weight pulls down on the springs, releasing the stored energy and causing the springs to bounce back up.
Can this setup be used for any practical applications?
Yes, this setup has been used in various mechanical systems, such as shock absorbers and car suspensions. It can also be used in toys or gadgets to create a fun and interactive motion.
How does the number of springs affect the overall motion?
The number of springs will affect the stiffness and strength of the system. More springs will result in a stiffer and more powerful motion, while fewer springs will create a softer and less intense motion.
Is there a limit to the number of springs that can be used in this setup?
Technically, there is no limit to the number of springs that can be used. However, adding too many springs may result in a system that is too heavy and difficult to control. It's important to find a balance between the number of springs and the desired motion.
