Series comparison test question
In summary, the problem is asking to find the summation from n=1 to infinity of 1/(n^3 + n^2). The conversation discusses some strategies for finding a suitable comparison to prove its convergence. It is suggested to use the integral test and replace the denominator with a smaller term that still converges. The conversation also addresses the convergence of 1/n^2 and why it does not converge to zero.
cue928
130
Problem:
Summation from n=1 to infinity: 1/(n^3 + n^2)
I understand, for example, another problem wherein it is 3/(4^n + 5) what you would compare that one to but how do you go about breaking this one up with two "n" terms? Are you supposed to, in general, pick the largest value of n? So perhaps compare it to 1/n^3 ?
Also, why does 1/n^2 from n=1 to inf. converge? Does it converge to zero?
1/n^2 does not converge to 0. It's a sum and all of the terms are positive. It can't possibly sum to zero. To prove it converges use an integral test. 1/n^3 is greater than 1/(n^3+n^2). That makes it a bad candidate for a comparison if you want to prove 1/(n^3+n^2) converges. Find something less than 1/(n^3+n^2) that you know converges.
But how do you find something a candidate for the test? That's what I don't see.
Take everything in the denominator and replace it with something less than or equal to the term you are replacing but that still converges. That will give you a fraction that's greater, right? Sorry, I got the less and greater backwards the first time I posted this.
Ok, big hint. Which is larger 1/(n^3+n^2) or 1/(n^2+n^2)? Can you show the latter converges?
FAQ: Series comparison test question
What is a series comparison test?
A series comparison test is a method used to determine the convergence or divergence of an infinite series. It involves comparing the given series to a known series whose convergence or divergence is already known.
What are the types of series comparison tests?
There are three main types of series comparison tests: the limit comparison test, the ratio test, and the root test. Each of these tests has its own criteria for convergence or divergence.
When should I use a series comparison test?
A series comparison test should be used when the terms of the given series cannot be easily manipulated, or when it is difficult to determine convergence or divergence using other methods such as the integral test or the direct comparison test.
What is the difference between the limit comparison test and the ratio test?
The limit comparison test compares the given series to a known series by taking the limit of their quotient. The ratio test compares the given series to a known series by taking the limit of the absolute value of their ratio.
How do I know which series to compare to?
The series to compare to should be chosen based on its convergence or divergence being known. Common series used for comparison include the geometric series, the p-series, and the harmonic series.
