MHB Series Convergence Or Divergence
The series $$\sum_{n = 2}^{\infty} \frac{(lnn)^{12}}{n^{\frac{9}{8}}}$$ converges as demonstrated through the limit comparison test with $$b = \frac{1}{n^{\frac{9}{8}}}$$. The limit of the ratio $$\frac{a}{b} = (lnn)^{12}$$ approaches infinity, indicating that the convergence of series a depends on series b. Since b converges (as $$\frac{9}{8} > 1$$), series a must also converge. Additional analysis shows that for large n, the logarithmic term is bounded, reinforcing the conclusion that the original series converges.
tmt1
I have
$$\sum_{n = 2}^{\infty} \frac{(lnn)^ {12}}{n^{\frac{9}{8}}}$$
I'm trying the limit comparison test, so I let $$ b = \frac{1}{n^{\frac{9}{8}}}$$ and $a = \sum_{n = 2}^{\infty} \frac{(lnn)^ {12}}{n^{\frac{9}{8}}}$
$\frac{a}{b} = (lnn)^ {12}$ therefore I know the limit of this as n approaches infinity would be infinity.
Since $\infty > 0$, $a$ should converge if $b$ converges or diverge if $b$ diverges.
Since b converges ($9/8 > 1$, so $ \frac{1}{n^{\frac{9}{8}}}$ should converge), then a must converge.
Therefore, the original series converges. Is this correct?
tmt said:
I have
First of all, you should note that any finite sum always gives a finite value.
For very large values of $\displaystyle \begin{align*} n \end{align*}$ (i.e. $\displaystyle \begin{align*} n > 2.661334067039 \cdot 10^{603} \end{align*}$) we have $\displaystyle \begin{align*} \left[ \ln{ \left( n \right) } \right] ^{12} < n^{\frac{1}{16}} \end{align*}$, so
$\displaystyle \begin{align*} \sum_{\textrm{Very large }n}^{\infty}{ \frac{\left[ \ln{ \left( n \right) } \right] ^{12}}{n^{\frac{9}{8}}} } &< \sum_{\textrm{Very large }n}^{\infty}{ \frac{n^{\frac{1}{16}}}{n^{\frac{9}{8}}} } \\ &= \sum_{\textrm{Very large }n}^{\infty}{ \frac{1}{n^{\frac{17}{16}}} } \end{align*}$
which is a convergent p series as $\displaystyle \begin{align*} \frac{17}{16} > 1 \end{align*}$.
Thus the first $\displaystyle \begin{align*} 2.661334067039\cdot 10^{603} \end{align*}$ terms will give a finite value, and we have shown that the remaining infinite sum converges by comparison, so that means $\displaystyle \begin{align*} \sum_{n = 2}^{\infty}{ \frac{\left[ \ln{\left( n \right) } \right] ^{12}}{n^{\frac{9}{8}}} } \end{align*}$ is convergent.
There are probably loads of proofs of this online, but I do not want to cheat. Here is my attempt: Convexity says that $$f(\lambda a + (1-\lambda)b) \leq \lambda f(a) + (1-\lambda) f(b)$$ $$f(b + \lambda(a-b)) \leq f(b) + \lambda (f(a) - f(b))$$ We know from the intermediate value theorem that there exists a ##c \in (b,a)## such that $$\frac{f(a) - f(b)}{a-b} = f'(c).$$ Hence $$f(b + \lambda(a-b)) \leq f(b) + \lambda (a - b) f'(c))$$ $$\frac{f(b + \lambda(a-b)) - f(b)}{\lambda(a-b)}...
  • · Replies 17 ·
