Series Convergence: Test for x Values
In summary, the question is to find the values of x for which the given series converges. The series can be rewritten as $\frac{(x-1)^n}{n!}$ and it can be observed that if x=0, the series will not converge. However, by recognizing the series as an exponential function, it can be concluded that the series converges for all values of x. Alternatively, the ratio test can be applied to find the values of x for which the series converges.
karush
MHB
3,269
\(\displaystyle (x-1)-\frac{(x-1)^2}{2!}+\frac{(x-1)^3}{3!}-\frac{(x-1)^4}{4!}+ ∙ ∙ ∙\)
well this looks like an alternating-series, the question is: at what value(s) of x does this
converge.
one observation is that if x=0 then all terms are 0 so there is no convergence, also I presume you can rewrite this as
$\frac{(x-1)^n}{n!}$ and then test for values of $x$
well this looks like an alternating-series, the question is: at value(s) of x does this
converge.
one observation is that is if x=0 then all terms are 0 so there is no convergence, also I presume you can rewrite this as
$\frac{(x-1)^n}{n!}$ and then test is for values of $x$
Remembering the well known series...
$\displaystyle \sum_{n=0}^{\infty} (-1)^{n}\ \frac{z^{n}}{n!} = e^{- z}\ (1)$
... that converges for any real or complex value of z, it is easy to observe that is...
$\displaystyle \sum_{n=1}^{\infty} (-1)^{n+1}\ \frac{(x-1)^{n}}{n!} = 1 - e^{- (x-1)}\ (2)$
... and the series (2) converges for any value of x...
Kind regards
$\chi$ $\sigma$
converge.
Even though recognising this series as an exponential function is the quickest method, if you didn't realize that, then you would have to apply the ratio test.
The ratio test states that for a series $\displaystyle \begin{align*} \sum{ a_n } \end{align*}$, the series will be convergent if $\displaystyle \begin{align*} \lim_{n \to \infty} \left| \frac{a_{n+1}}{a_n} \right| < 1 \end{align*}$. But in your case, you have a function of x, which gives a different series for every x that is put in. So what you have to do is to evaluate $\displaystyle \begin{align*} \lim_{n \to \infty} \left| \frac{a_{n+1}}{a_n} \right| \end{align*}$ in terms of x, then set this expression less than 1 and solve for x. This will tell you nearly all the values of x for which your function gives a convergent series (you need to check the points where this limit is equal to 1 separately, as the ratio test is inconclusive there...)
FAQ: Series Convergence: Test for x Values
What is the purpose of the test for x values in series convergence?
The test for x values in series convergence is used to determine whether a given series will converge or diverge based on the value of x. This is important because it allows scientists to understand the behavior of a series and make accurate predictions about its long-term behavior.
How is the test for x values different from other tests for series convergence?
The test for x values is specifically used for series where the terms involve x raised to a power. This makes it different from other tests, such as the ratio test or the integral test, which are used for more general series.
What is the general formula for the test for x values?
The general formula for the test for x values is given by the limit as n approaches infinity of |x|^(n+1)/n. If this limit is less than 1, the series will converge. If it is greater than 1, the series will diverge. If it is equal to 1, the test is inconclusive and another test must be used.
When should the test for x values be used?
The test for x values should be used when dealing with a series where the terms involve x raised to a power. This can include series involving polynomials, logarithms, or trigonometric functions, among others.
What are the limitations of the test for x values?
The test for x values is only applicable to certain types of series, which limits its usefulness in certain situations. Additionally, the test can sometimes give inconclusive results, requiring the use of another test to determine convergence or divergence. Finally, the test does not provide information about the rate of convergence, which may be important in certain scientific applications.
