Series inequality induction proof
Aristarchus_
How do I show that ##1+2^{2} + 3^{3} +...+n^{2} > \frac {1}{3} \cdot n^{3}## ?
k
My first attempt was ##... + n^{2} + (n+1)^{2} > \frac {1}{3} n^{3} + (n+1)^{2}##
then we must show that ##\frac {1}{3} n^{3} + (n+1)^{2} > \frac {1}{3} (n+1)^{3}##
We evaluate both sides and see that the LHS is indeed bigger than RHS. However, this solution is inconsistent so I am asking for some guidance as to a better method...
What you have done does not look right as an attempt at an inductive proof.
Please make a genuine attempt at a proof by induction.
Is there a typo in your statement of the problem? In ##1+2^2+3^3+...+n^2##, I fail to see a pattern in the exponents. Is ##3^3## correct? Is ##n^2## correct?
Aristarchus_ said:
Homework Statement:: How do I show that ##1+2^{2} + 3^{3} +...+n^{2} > \frac {1}{3} \cdot n^{3}## ?
Relevant Equations:: k
Assuming you mean <br /> 1+2^{2} + 3^{2} + \dots +n^{2} &gt; \frac {1}{3} n^{3}<br /> I would use <br /> 1 + 2^2 + 3^2 + \dots + n^2 = \tfrac16n(n+1)(2n+1). But if I was required to prove that result rather than just state it, then I would prefer your approach since it requires slightly less work.
What do you mean by the solution is inconsistent?
