Series Test for convergent and divergent
In summary, the conversation discusses a series, Ʃ √n/(ln(n))^n, from n=2 to ∞, and possible methods for determining whether it converges or diverges. The conversation mentions using the Ratio Test and l'Hopital's Rule, but ultimately suggests using the Comparison Test by showing that (ln(n))^n will eventually dominate any power series.
mikbear
Ʃ √n/(ln(n))^2
from n=2 to ∞
I tried doing ratio test and gotten
[√(n+1)*(ln(n))^n] / [(ln(n+1))^(n+1) * √n]
to find the limit, do i cont by using Hopstal rule?
mikbear said:
Ʃ √n/(ln(n))^2
from n=2 to ∞
That is not correct. It should be
$$ \frac{\sqrt{n+1}~(ln(n))^2}{\sqrt{n}~(ln(n+1))^2}$$
In any case, I don't think the Ratio Test is going to be much help here. What other tests do you know?
The absolute first check you should always make is to check that the nth term approaches 0. l'Hopital's should help there.
I made a mistake in the question its suppose to be power of n
Ʃ √n/(ln(n))^n
from n=2 to ∞
I have learned root test, integral test, comparison and limit test.
however I do not see how these will help solve this question.
Ʃ √n/(ln(n))^n
from n=2 to ∞
That's little more subtle. Can you show (ln(n))^n will eventually dominate any power series? For example, (ln(n))^n>n^2 for sufficiently large n? That would let you make a comparison test.
Oh. thanks for the tip. I gona try it rite now. Thanks
FAQ: Series Test for convergent and divergent
What is the series test for convergent and divergent?
The series test is a method used to determine whether a given series, or sequence of numbers, converges or diverges. It helps us understand the behavior of infinite sums and their sums as the number of terms approaches infinity.
What are the different types of series tests?
There are several types of series tests, including the comparison test, the ratio test, the root test, the integral test, and the alternating series test. Each one has its own set of conditions and criteria for determining convergence or divergence.
How do you use the comparison test?
The comparison test involves comparing a given series to another series with known convergence or divergence. If the known series converges and the given series is smaller than it, then the given series also converges. If the known series diverges and the given series is larger than it, then the given series also diverges.
Can a series pass multiple tests for convergence or divergence?
Yes, a series can pass multiple tests for convergence or divergence. This is because different series tests have different criteria and conditions for determining convergence or divergence. However, if a series fails one test, it is considered divergent.
Why is it important to know whether a series is convergent or divergent?
Knowing whether a series converges or diverges is important in many mathematical and scientific applications. It allows us to accurately calculate and predict values, analyze behavior, and make informed decisions in various fields such as physics, engineering, and economics.
