Set of 2-dimensional orthogonal matrices equal to an union of sets
mathmari
MHB
5,049
Hey! :giggle:
The set of $2$-dimensional orthogonal matrices is given by $$O(2, \mathbb{R})=\{a\in \mathbb{R}^{2\times 2}\mid a^ta=u_2\}$$ Show the following:
(a) $O(2, \mathbb{R})=D\cup S$ and $D\cap S=\emptyset$. It holds that $D=\{d_{\alpha}\mid \alpha\in \mathbb{R}\}$ and $S=\{s_{\alpha}\mid \alpha\in \mathbb{R}\}$, where $d_{\alpha}=\begin{pmatrix}\cos (\alpha) & -\sin (\alpha) \\ \sin (\alpha ) & \cos (\alpha )\end{pmatrix}$ and $s_{\alpha}=\begin{pmatrix} \cos (\alpha )& \sin (\alpha ) \\ \sin (\alpha) & -\cos(\alpha)\end{pmatrix}$.
(b) For all $\alpha\in \mathbb{R}$ is $B_{\alpha}$ an orthonormal basis of $\mathbb{R}^2$. It holds that $B_{\alpha}=(e_{\alpha}, f_{\alpha})$, where $e_{\alpha}\begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) \\ \sin \left (\frac{\alpha}{2}\right )\end{pmatrix}$ and $f_{\alpha}\begin{pmatrix}-\sin \left (\frac{\alpha}{2}\right ) \\ \cos \left (\frac{\alpha}{2}\right )\end{pmatrix}$
(c) Calculate $M_{B_{\alpha}}(\sigma_{\alpha})$,where $\sigma_{\alpha}(x)=s_{\alpha}x$.
I have done the following :
(a) To show that $D\cap S=\emptyset$, we assume that this is not true, i.e. that there is a matrix that belongs to $D$ and to $S$. Then for some $\alpha\in \mathbb{R}$ it must hold that $-\sin (\alpha)= \sin (\alpha) \Rightarrow \sin (\alpha)=0$ and that $\cos (\alpha)= -\cos (\alpha) \Rightarrow \cos (\alpha)=0$. There is no such $\alpha$ and therefore the intersection is empty.
How can we show that $O(2, \mathbb{R})=D\cup S$ ?
(b) We have to show that $e_{\alpha}$ and $f_{\alpha}$ are linearly independent, so that we can say that $B_{\alpha}$ is a basis of $\mathbb{R}^2$, right? To show also that itis an orthonormal basis, we have to show that the vectors $e_{\alpha}$ and $f_{\alpha}$ are orthogonal, i.e. their dot product is equal to $0$ and that it is normal, i.e. that both vectors have length $1$, right?
(c) Do we have to write the columns of $s_{\alpha}$ as a linear combination of $e_{\alpha}$ and $f_{\alpha}$ ? :unsure:
Hey mathmari!
Suppose we consider a matrix $a$ with column vectors $\vec a$ and $\vec b$.
What can we deduce from the condition $a^t a = u_2$? 🤔
mathmari said:
(b) show that the vectors $e_{\alpha}$ and $f_{\alpha}$ are orthogonal, i.e. their dot product is equal to $0$ and that it is normal, i.e. that both vectors have length $1$, right?
Yep. (Nod)
What we need, is to find the images of $e_\alpha$ and $f_\alpha$ in terms of $e_\alpha$ and $f_\alpha$.
It may help to write $s_{\alpha}$ as a linear combination of $e_{\alpha}$ and $f_{\alpha}$. :unsure:
What can we deduce from the conditions $a^t a = u_2$? 🤔
We have that $\vec{a}\cdot \vec{a}=\vec{b}\cdot \vec{b}=1$ and $\vec{a}\cdot \vec{b}=0$, right? :unsure:
Will the coefficients of the linear combination be matrices? :unsure:
Yep. 🤔
Perhaps we should consider the matrix given by $B_\alpha$.
It transforms the unit vectors to $e_\alpha$ and $f_\alpha$.
So we should be able to construct $M_{B_\alpha}(\sigma_\alpha)$ using $B_\alpha$ and its inverse. 🤔
Yep. 🤔
This properties are satisfied by the columns of the mayrices of $D$ and $S$, right? So does the desired result just follow then? :unsure:
We have that $B_{\alpha}= \begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) & - \sin \left (\frac{\alpha}{2}\right ) \\ \sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix}$.
Do you mean that $M_{B_\alpha}(\sigma_\alpha)=B_\alpha^{-1}B_\alpha$ ? :unsure:
mathmari said:
This properties are satisfied by the columns of the matrices of $D$ and $S$, right? So does the desired result just follow then?
Not necessarily.
That is what we still have to prove.
We have to prove that any $\vec a$ can be written as $(\cos\alpha,\sin\alpha)$. Can it?
And additionally that any $\vec b$ is either $(-\sin\alpha,\cos\alpha)$ or $(\sin\alpha,-\cos\alpha)$.
Can we prove that? 🤔
Close... but that right side is just identity isn't it. Something is missing... (Sweating)
Not necessarily.
Do we prove that by proving that these two vectors are orthognal to each otherand have length $1$ ? :unsure:
Ah yes. Should it be $M_{B_\alpha}(\sigma_\alpha)=B_\alpha^{-1}(s_\alpha)B_\alpha$ ? :unsure:
We should observe that any vector of length 1 must be on the unit circle, which implies that it can be written as $(\cos\alpha,\sin\alpha)$ for some $\alpha$.
And there are only 2 unit vectors that are orthogonal in 2 dimensions (dot product 0).
That is either $(\sin\alpha,-\cos\alpha)$ or $(-\sin\alpha,\cos\alpha)$. 🤔
Yep. (Nod)
And since $B_\alpha$ is an orthogonal matrix, its inverse is the same as its transpose. 🤔
Can we just say that any vector of length 1 must be on the unit circle, which implies that it can be written as $(\cos\alpha,\sin\alpha)$ for some $\alpha$, or do we have to prove that? :unsure:
So we have that
\begin{align*}M_{B_\alpha}(\sigma_\alpha)&=B_\alpha^T s_\alpha B_\alpha \\ & = \begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) & \sin \left (\frac{\alpha}{2}\right ) \\ -\sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix} \begin{pmatrix} \cos (\alpha )& \sin (\alpha ) \\ \sin (\alpha) & -\cos(\alpha)\end{pmatrix} \begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) & - \sin \left (\frac{\alpha}{2}\right ) \\ \sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix} \\ & = \begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) & \sin \left (\frac{\alpha}{2}\right ) \\ -\sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix} \begin{pmatrix} \cos (\alpha )\cos \left (\frac{\alpha}{2}\right )+\sin (\alpha)\sin \left (\frac{\alpha}{2}\right )& -\cos (\alpha )\sin \left (\frac{\alpha}{2}\right )+\sin (\alpha)\cos \left (\frac{\alpha}{2}\right ) \\ \sin (\alpha )\cos \left (\frac{\alpha}{2}\right )-\cos (\alpha)\sin \left (\frac{\alpha}{2}\right ) & -\sin (\alpha )\sin \left (\frac{\alpha}{2}\right )-\cos (\alpha)\cos \left (\frac{\alpha}{2}\right )\end{pmatrix} \\ & = \begin{pmatrix}\cos \left (\frac{\alpha}{2}\right ) & \sin \left (\frac{\alpha}{2}\right ) \\ -\sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix} \begin{pmatrix} \cos \left (\frac{\alpha}{2}\right )& \sin \left (\frac{\alpha}{2}\right ) \\ \sin \left (\frac{\alpha}{2}\right ) & \cos \left (\frac{\alpha}{2}\right )\end{pmatrix}
\\ & = \begin{pmatrix} \cos^2 \left (\frac{\alpha}{2}\right )+\sin^2 \left (\frac{\alpha}{2}\right )& 2\cos\left (\frac{\alpha}{2}\right )\sin \left (\frac{\alpha}{2}\right ) \\ 0 & -\sin^2 \left (\frac{\alpha}{2}\right )+\cos^2 \left (\frac{\alpha}{2}\right )\end{pmatrix} \\ & = \begin{pmatrix} 1& 2\cos\left (\frac{\alpha}{2}\right )\sin \left (\frac{\alpha}{2}\right ) \\ 0 & -\sin^2 \left (\frac{\alpha}{2}\right )+\cos^2 \left (\frac{\alpha}{2}\right )\end{pmatrix} \end{align*}
:unsure:
Yes, we can just state that. (Nod)
mathmari said:
So we have that
Looks about right, although I didn't check the calculations.
We can still simplify the result a bit more can't we? We can use the double angle formulas. 🤔
