LMAO! Force of habit!tiny-tim said:Hi Femme_physics!
(wouldn't it have been quicker to type it rather than attach a picture? )
If f(x) = -x2 + 4
then f(-10) = -(-10)2 + 4.
I don't know what --102 + 4 would mean, but I suspect it would be --(102) + 4 = (102) + 4
Femme_physics said:Tiny-tim! Good to see you! Where've you been hiding? ^^ :)
tiny-tim said:I don't know what --102 + 4 would mean, but I suspect it would be --(102) + 4 = (102) + 4
Mark44 said:these things - <> - angle brackets
Char. Limit said:Oh, is that what they're called? I just call them arrow thingies.
Char. Limit said:To be fair, I also call brackets "square thingies" and paretheses "round thingies".
Femme_physics said:LOL. I actually knew you were joking, Char, I just wanted to jokingly patronize over you and sound smart for a milisecond :D
Brackets in a function are used to specify the parameters or variables that the function will operate on. They are also used to enclose any additional instructions or arguments that the function may require.
To set x equal to something in a function, you can use the equal sign (=) followed by the value or expression that you want x to be equal to. For example, if you want x to be equal to 5, you can write x = 5. This will assign the value of 5 to the variable x.
Yes, you can use brackets to define multiple parameters in a function. Simply separate the parameters with a comma inside the brackets. For example, if you have two parameters x and y, you can write (x, y) inside the brackets.
To specify arguments in a function using brackets, you can write the arguments inside the brackets after the function name. For example, if you have a function called myFunction and it requires two arguments x and y, you can write myFunction(x, y).
Brackets are not necessary when defining a function, but they are typically used to specify the parameters and arguments of the function. If the function does not require any parameters or arguments, then brackets may not be necessary.
