Sets and equivalence between images of sets
In summary, A set is a collection of distinct objects, called elements, that have a common characteristic or property. The cardinality of a set is the number of elements in the set, denoted by |S|, where S is the set. An equivalence relation between sets is a relation that is reflexive, symmetric, and transitive. A subset is a set that contains all the elements of another set, while a proper subset is a subset that does not contain all the elements of the original set. The equivalence between sets can be determined by checking if the sets have the same cardinality and if there is a one-to-one correspondence between the elements of the sets.
mtayab1994
584
Let f be a function from E to F . Prove that f is an injective function if and only if for all A and B subsets of P(E)^2.
[tex]f(A\cap B)=f(A)\cap f(B)[/tex]
Well since we have "if and only if" that means we have an equivalences so for.
[tex]\Rightarrow[/tex]
If f is an injective function so it's trivial to say that
For: [tex]\Leftarrow[/tex]
We have to show a double inclusion so since:
[tex]A\cap B\subset A[/tex] and [tex]A\cap B\subset B[/tex] then:
[tex]f(A\cap B)\subset f(A)[/tex] and [tex]f(A\cap B)\subset f(B)[/tex]
so therefore: [tex]f(A\cap B)\subset f(A)\cap f(B)[/tex]
And the other way around:
let [tex]y\in f(A)\cap f(B)[/tex] so there exists [tex]x\in A\cap B[/tex] such that f(x)=y then by the definition of an image we get that [tex]f(x)=y\in f(A\cap B)[/tex] so therefore:
[tex]f(A)\cap f(B)\subset f(A\cap B)[/tex]
So finally : [tex]f(A\cap B)=f(A)\cap f(B)[/tex]
Hence f has to be an injective function. Any help or any remarks would be very well appreciated.
No, it may be easy but it isn't trivial. You have to prove it. Your assumption is ##f## is injective and you have to show for any ##A,B## that ##f(A\cap B)=f(A)\cap f(B)##. In particular you argument must use the fact that ##f## is 1-1 somewhere.
Here you you should be assuming that for any ##A,B## that ##f(A\cap B)=f(A)\cap f(B)## and you must show that ##f## is 1-1. So what's the argument below about? Are you trying to show what you are assuming?
But that is given.
You can't just claim it. You have to prove it.
Related to Sets and equivalence between images of sets
1. What is a set?
A set is a collection of distinct objects, called elements, that have a common characteristic or property. Sets are often represented by curly braces { } and the elements are separated by commas.
2. What is the cardinality of a set?
The cardinality of a set is the number of elements in the set. It is denoted by the symbol |S|, where S is the set. For example, if a set contains the elements 1, 2, and 3, the cardinality of the set is 3.
3. What is an equivalence relation between sets?
An equivalence relation between sets is a relation that is reflexive, symmetric, and transitive. This means that for any set A, the relation R must satisfy the following properties: (1) a is related to a for all a ∈ A (reflexive), (2) if a is related to b, then b is related to a for all a, b ∈ A (symmetric), and (3) if a is related to b and b is related to c, then a is related to c for all a, b, c ∈ A (transitive).
4. What is the difference between a subset and a proper subset?
A subset is a set that contains all the elements of another set. A proper subset, on the other hand, is a subset that does not contain all the elements of the original set. In other words, a proper subset is a subset that is not equal to the original set.
5. How is the equivalence between sets determined?
The equivalence between sets can be determined by checking if the sets have the same cardinality and if there is a one-to-one correspondence between the elements of the sets. This means that each element in one set must correspond to exactly one element in the other set, and vice versa. If these conditions are met, then the sets are considered equivalent.
