Setting a family of sets equal to the empty/null set?
  • Thread starter pandaBee
  • Tags
    Set Sets
In summary, the problem asks to prove that for every family of sets, A, if ∪F = A then A is a member of the family. The attempt at a solution states that if F is an empty set, then ∅ is a member of the family. The existence part of the proof is to show that there exists a set x such that x is a member of A. The uniqueness part of the proof is to show that x is the only member of A. The proof by contradiction is to show that there exists a family F' such that ∪F' = ∅ and ∅∈F'. If F is not an empty set, then the consequent is FALSE and the contradiction is
pandaBee
23
Suppose A is a set, and for every family of sets F, if ∪F = A then
A ∈ F.
Prove that A has exactly one element. (Hint: For both the existence
and uniqueness parts of the proof, try proof by contradiction.)
Let A be an arbitrary set
Suppose ∀F(∪F=A⇒A∈F)
Want to prove:
∃!x(x∈A) (A has a single, unique element.)
Existence:
Want to prove:
∃x(x∈A)
I use the Hint and use proof by contradiction, we add the assumption that
∀x(x∉A) into our list of givens.
But this means that A = ∅; then plugging this into our other given:
∀F(∪F=∅⇒∅∈F)
Let F' be the family set F' = ∅
then ∪F'=∅ and thus ∅∈F'
but this is a contradiction, since ∅∈F'=∅ is False.
Is this a legal move - setting F to the empty set?
If I don't set F to the empty set, then ∀F(∪F=∅⇒∅∈F) is true as far as I can tell, and there is no contradiction in assuming the negated goal.
is F is a family of empty sets, then since the empty sets contain no elements the union of the family set of empty sets is just the empty set.
However, is F IS an empty set then ∅∈F'=∅ and we've found our contradiction.
Any insight on this?
It looks correct to me. If we write ##F=\{F_i|i\in I\}##, we can write ##\bigcup F=\bigcup_{i\in I}F_i##. If ##F=\varnothing##, this rewrite still works. We just have to take ##I=\varnothing##. So when ##F=\varnothing##, we have $$\bigcup \varnothing =\bigcup F=\bigcup_{i\in\varnothing} F_i.$$ Now what's a union with an empty index set? Does it make sense? I think it does, because ##x\in \bigcup_{i\in\varnothing}## implies ##\exists i\in\varnothing~~ x\in F_i##, which is false. So ##\bigcup_{i\in\varnothing}F_i## must be empty. We simply have ##\bigcup \varnothing=\varnothing##.
Also, the problem statement says "for every family of sets". What is a family of sets? It's just a set, right? We use the word "family" only because "set of sets" can sound weird. And a set of sets is just a set, because all elements of all sets are sets. So "for every family of sets F" should mean "for all sets F". I don't see a reason to exclude the empty set, unless this book defines "family" in an unexpected way.
Likes 1 person
The question seems to be posed in a misleading way. Is that really the exact way it was written in the text or assignment sheet? The way it is written confuses the issue of whether F is an index set for the family or a member of the family of sets. This in turn confuses x with {x}, which is at the heart of the problem and so makes progress very difficult.
I presume what the problem is really asking is to prove that, given
$$\forall\mathscr{F}(\bigcup_{S\in\mathscr{F}}S=A\rightarrow(A\in \mathscr{F} ))$$
##A## must have exactly one element.
We can then re-write your working as:
$$\forall\mathscr{F}(\bigcup_{S\in\mathscr{F}}S=\emptyset \rightarrow(\emptyset \in \mathscr{F} ))$$
We then instantiate ##\emptyset## for ##\mathscr{F}## in this to get:
$$\bigcup_{S\in\emptyset}S=\emptyset \rightarrow(\emptyset \in \emptyset )$$
The consequent is well-defined and FALSE.
The antecedent is
$$\emptyset=\bigcup_{S\in\emptyset}S\equiv\{x\vert\exists S(S\in\emptyset\wedge x\in S)\}$$
This is TRUE because ##S\in\emptyset## is false for all ##S##.
Hence the implication is FALSE and the contradiction is obtained.
Andrewkirk, are you objecting against the notation ##\bigcup F##? That's a fairly common notation for the union of all the sets that are elements of F. So if ##F=\{F_i|i\in I\}##, we have ##\bigcup F=\bigcup_{i\in I} F_i##.
Interesting. I haven't come across that notation. There is no strict logical objection to formally defining the symbol string ##\bigcup F## to mean that but it seems unnecessarily obscure to me and, unless the definition is provided, it will mislead. One expects the operands on which any union operator operates to be the sets whose union is being taken, so it seems to me that unnecessary confusion is fostered by this presentation in which the operand ##F## is instead the set of sets whose union is being taken - ie the index set. Index sets have always, in my experience, been in the subscript to union operators, as in ##\bigcup_{S\in\mathscr{F}}S##. Apart from being clearer, this notation has the advantage of not using any conventions other than those that are universally recognised in ZF set theory.
My notation generally follows that of Munkres in 'Topology - a First Course' but most of what I come across on wikipedia, Wolfram and stackexchange seems to follow those same conventions.
Thanks for the feedback guys, here's the rest of the proof just for the sake of completeness:
Continuing from the first post:
However, if F IS an empty set then ∅∈F'=∅ and we've found our contradiction; therefore ∃x(x∈A)
Now I prove Uniqueness:
let P(x) = ∃x(x∈A)
We assume P(x) and P(y) and try to prove that x = y; that is that x is unique.
Givens:
x∈A
y∈A
∀F(∪F=A⇒A∈F)
Goal: x=y
Proof by contradiction: assume x=/=y;
I define the family set F={X,Y,Z_1,Z_2...Z_n} to correspond with A(defined in the next line) where X={x}, Y={y}, Z_1={z_1}, so on so forth
A is a set that contains x and y of the form A={x,y,z_1,z_2,...z_n} (Spans all possibilities for A)***
but then ∪F = {x,y,z_1,z_2,...z_n}, therefore ∪F = A
but it is clear that A∉F, which is a contradiction: therefore x=y.
Therefore ∃!x(x∈A) and the proof is complete.
I kind of feel sketchy about the *** part of the proof, if there's a better way to write it out I'd love to see it. Thanks again.
And sorry about the messy symbols, I'm in the process of learning Latex and I've been using an online math symbol typer to cope in the meanwhile. Is there perhaps a better way of typing out symbols than latex or is learning latex the best thing to do?
You can write the *** part as:
Define ##C\equiv A-\{x,y\}##, ##X\equiv\{x\}, Y\equiv\{y\}##. Then ##A=X\cup Y\cup C##.
By the way, in maths one needs to avoid statements like 'It is clear that' (two lines below ***). If it is clear, a reason can be given, and should be.
Here is a somewhat similar approach to yours that avoids that sort of problem.
We have already proven that there is at least one element of ##A##. Let us call it ##x##.
Define ##C\equiv A-\{x\}##, ##X\equiv\{x\}##. Then ##A=X\cup C## and ##x\in A-C##..
Then we just have to prove that ##C## is empty.
Consider the set (or 'family') ##\mathscr{F}=\{X,C\}##.
we have ##\bigcup_{S\in\mathscr{F}}S=X\cup C=A## hence, by the original premise, ##A\in\mathscr{F}=\{X,C\}##.
So we have ##A=X\vee A=C##. Now we know the latter is false because ##x\in A-C##. So the former must be true: ##A=X=\{x\}##. So ##y\in X\to y=x##.
Related to Setting a family of sets equal to the empty/null set?
1. What does it mean to set a family of sets equal to the empty/null set?
Setting a family of sets equal to the empty/null set means that all the sets within the family contain no elements. In other words, the family itself is considered to be empty.
2. How is setting a family of sets equal to the empty/null set useful in mathematics?
This concept is useful in proving mathematical theorems and statements. It allows us to show that a certain property or condition holds true for all sets in the family, even if the family itself is empty.
3. Can a family of sets be equal to both the empty set and a non-empty set?
No, a family of sets can only be equal to one set at a time. If a family is equal to the empty set, then it cannot contain any non-empty sets. And if a family contains a non-empty set, then it cannot be equal to the empty set.
4. How do we show that a family of sets is equal to the empty set?
In order to show that a family of sets is equal to the empty set, we must prove that all the sets within the family are also equal to the empty set. This can be done by showing that each set in the family has no elements.
5. Is the empty set the same as the null set?
Yes, the terms "empty set" and "null set" are often used interchangeably in mathematics. Both refer to a set that contains no elements.
