Zarathuztra
- 36
Setting up a test stand that will need a controller to cycles a device ON and OFF at an adjustable time interval (allows me to make the ON duration and OFF duration whatever I want). It will also need to keep a count, so I can track the cycles count and also set a limit on cycles so it will stop when it reaches a certain cycle count. Tests will go normally for 10k+ cycles, but some could go over 50k cycles.
12VDC battery supply is going to go into the controller and it will be powering a 12VDC coil.
I've been trying to google but my result continuously land me to software/computer testing stuff.. Looking for some advice of recommended equipment or setups to handle the requirements. Or at least a company or website that can be a solid resource to figuring out what I need to make the controller.
Voltage: 12V DC battery
Current Max: 6A
Power Max: 70W
Frequency of cycling: likely ON/OFF 2 times a minute at the most, usually slow than that. shortest duration will be ON part of the cycles and that should be a 4 seconds at minimum.
The controller will only be controlling (1) device.
Current Max: 6A
Power Max: 70W
