Setting up a particular equation with (cos(x))^2
  • Thread starter batmankiller
In summary, the student is trying to find a particular solution to the differential equation using various methods, but is not sure where to start.
batmankiller
Find a particular solution yp of the differential equation
2y''+9y'+2y=(cos(x))^2
I'm not really sure where to start? I solve for the homogeneous solution and get C1e^ -4.26556+C2e^-.2344355629=0. I'm just not sure where to go from there. Should I do
y(x)=(Acos(x)+Bsin(x))^2 since it's just cos (x)*cos(x) or is not that right approach?
[tex]cos^{2}(x)[/tex] can be broken up using the half angle formula. You'd get a polynomial (degree one) and a trig function that is expandable under Euler's Formula. Add the particular solutions together to get the final particular solution.
so (cos(x)^2) is ((1+cos (2x))/2.
Which is 1/2 + cos(2x)/2. Am I missing something to get it into a degree one term and a trig function?
For that I get A+ B*cos(2x)+C*sin(2x)?
Sorry, not degree one. I meant it has a constant added to a trig function. But you can solve the equation and get particular solutions by guessing that [tex]y = \frac{1}{4}[/tex] (for one solution) and that [tex]y = Re(Ae^{2i\theta})[/tex] where A is some constant. Or you can use your method and simply guess [tex]A sin(2\theta)+Bcos(2\theta)[/tex]. Add that guess to your other particular solution ([tex]y = \frac{1}{4}[/tex]), then add your particular solutions to your homogeneous solution. This will result in the general solution of the differential equation.
Ah ok, I don't even need the general solution, just the particular solution, so should I just consider the two particular solutions of Asin(2x)+Bcos(2x) and y=1/4 (Solving the constants A and B?)
Yup. Add the two particular's together and you're done!
FAQ: Setting up a particular equation with (cos(x))^2
1. What is the purpose of setting up an equation with (cos(x))^2?
The purpose of setting up an equation with (cos(x))^2 is to solve for the value of x that satisfies the equation. This is useful in many mathematical and scientific applications, such as finding the roots of a polynomial or determining the position of an object at a given time.
2. How do I set up an equation with (cos(x))^2?
To set up an equation with (cos(x))^2, first identify the given information and what you are solving for. Then, use the properties of cosine to manipulate the equation until you have (cos(x))^2 on one side and all other terms on the other side. Finally, apply algebraic techniques to solve for the value of x.
3. What are some common mistakes to avoid when setting up an equation with (cos(x))^2?
Some common mistakes when setting up an equation with (cos(x))^2 include forgetting to use the correct properties of cosine, incorrectly manipulating the equation, and not isolating (cos(x))^2 on one side of the equation. It is important to double check your work and make sure all steps are accurate.
4. Can (cos(x))^2 be used in any type of equation?
Yes, (cos(x))^2 can be used in any type of equation as long as it is relevant to the problem being solved. It is a versatile trigonometric function that can be used in a variety of mathematical and scientific contexts.
5. How can I check my answer when using (cos(x))^2 in an equation?
To check your answer when using (cos(x))^2 in an equation, you can substitute your solution for x back into the original equation. If the equation holds true, then your solution is correct. You can also use a graphing calculator to visually confirm your answer.
