- #36
Cyrus
- 3,238
- 17
Gokul43201 said:Prove what? Mpemba? Sure! Let me know when you're visiting these parts.
I was just giving you a hard time, I know its true!
In my experience, the bubbles nucleate at the location of the heat source.Gokul43201 said:the majority of bubbles do nucleate on the container walls.
Yep!cyrusabdollahi said:Do you think it all boils instantly into a vapor?
At least you agree that the entire mass got heated to boiling all at once.cyrusabdollahi said:They did that because the microwaves do not agitate it like an open heat source. They vibrate the polar molecules. When you pick the cup up, you agitate it and it rapidly nucleates.
Not quite the same thing.
Which makes sense since that's where the energy is to generate the phase change.
In the case of a microwave oven, you can get some peculiar results.
Yep!
At least judging by the number of cups water I've mopped up off the bottom of the microwave after they explosively emptied.
The usual scenerio was that I heard a whoomp.cyrusabdollahi said:Did you touch them or add anything to it?
I was more referring to the fact that only the part of the pot in contact with the heater bubbles. Sure, if you heat it evenly then it all bubbles. You do need energy to make this happen.WhyIsItSo said:Try it, however, with something that transmits the heat more evenly, and you will see a lot more bubbles forming on the sides.
I'm sure this is what's happening, when the conditions are just right.WhyIsItSo said:Hence, the water can superheat - be hotter than the boiling point without actually boiling.
