Setup Windows on HP laptop without nlite editor if possible
In summary, the HP 530 notebook core duo processor does not have the driver to install Windows XP on its hard disk. The HP 530 notebook core duo processor was originally purchased with Linux installed on it. The HP 530 notebook core duo processor was recommended to try to install Windows XP by adding the HP drivers. The HP 530 notebook core duo processor was unable to install Windows XP because a .sys file was corrupted. The HP 530 notebook core duo processor was able to install Windows XP by changing the BIOS settings to allow SATA access.
pit
10 days ago I bought a brand new HP note book (HP 530 notebook core duo processor) and I'm still unable to install Windows XP SP2 on its hard disk.
I know that I bought the cheapest HP notebook with core duo processor, but didn’t expect to not work.
When I try to install Windows XP I always get an error that a .sys file is corrupted (each time a different file). I think that both the hard drive and CD drive are good since Linux was previously installed on it.
I got a reccomendation to add the HP drivers trying to edit the Windows XP CD installation kit with a free software called Windows setup editor nLite
I'm looking for a decent solution without any nLite or other 'windows configuration tool' suitable for a new notebook and a non computer person.
If anyone had the same problem, I would be glad to get a simpler solution to make my new notebook to work with Win XP SP2. Also, a CD with drivers was not included in laptop kit.
Computer science news on Phys.org
hello pit, I have a same problem on a same type HP(core duo on 1,6MHz) . when I'm trying to install windows at the and of process i got i massage that it can't find HDD at all. Did you find a solution somehow. If you did please post it here. Thanks
Are you trying to install it in a second partition on a HD > 100gb?
If so the first partition can only be about 95 gb.
A little higher and you get missing corrupt files message.
Another bit higher and you get can't find HD message.
I just went thru this grief on an HP 9410.
Edit: All the drivers could be installed afterwards, once I figured out the partitioning thing.
Hi NoTime. I solved my problem .It was so obvious:) . It's a brand new notebook with freedos(dos) and i tried to install windows as you know. What i find out later, problem were SATA drivers. Problem is SATA HDD. Only thing i had to do is change bios setup for SATA HDD -to put disable . (On different computers maybe to change it to IDE mod(BIOS)) I installed windows and its ok now. For other that have same problem and don't have this option in bios- there is a program nlite to incorporate sata drivers on boot cd with windows and install it together. thank you for helping me :)
Glad you were able to solve your problem.
The issue I was having is that the boot loader does not have access to the drivers and is dependent on the older BIOS functions it understands until it can load the drivers. I found out when I used the XP install format routine and it would only format the first 100g of the HD.
Disabling SATA was a fast solution for me too, but not completely satisfactory since I payed for a SATA hard disk. It's now solved with the help of nlite software.
pit said:
I got a reccomendation to integrate the drivers trying to edit the XP CD installation kit with a free software http://www.softspecialist.com/nLite-3244/nLite.htm"
What I would to remark is that in windows vista nlite cannot be used, but, fortunately, there is http://www.softspecialist.com/vLite-3329/vLite.htm" which mainly can do the same thing as nlite, however certain knowledge is needed. You should look for someone who can do it and spend also some additional money (as I did).
FAQ: Setup Windows on HP laptop without nlite editor if possible
Can I set up Windows on my HP laptop without using the nlite editor?
Yes, it is possible to set up Windows on an HP laptop without using the nlite editor. There are alternative methods for installing Windows, such as using a USB drive or external DVD drive. Additionally, some newer HP laptops come with a built-in recovery partition that allows you to reinstall Windows without using any external tools.
What is the nlite editor and why should I avoid using it?
The nlite editor is a tool that allows you to customize your Windows installation by removing components and integrating updates and drivers. While it may be useful for some users, it is not recommended for the average user as it can cause issues with the stability and functionality of the operating system.
How can I create a bootable USB drive for installing Windows on my HP laptop?
You can create a bootable USB drive by using a tool such as Rufus or the official Windows USB/DVD Download Tool. These tools will help you format the USB drive and copy the Windows installation files onto it, making it ready for use as a bootable device.
Will setting up Windows on my HP laptop without the nlite editor affect the performance of my computer?
No, setting up Windows without the nlite editor should not affect the performance of your computer. As long as you follow the proper installation procedures and use official Windows installation media, your computer should run as intended.
Can I use the built-in recovery partition on my HP laptop to set up Windows without losing my files?
Yes, using the built-in recovery partition should allow you to reinstall Windows without losing your personal files. However, it is always recommended to back up important files before performing any major changes to your computer, just in case.
