Sextenions (6D hypercomplex numbers)
  • Thread starter EinsteinKreuz
  • Tags
    Numbers
In summary, the conversation discusses the construction of a 6D complex number system using a Cayley table, with the rule that i2=j2=k2=l2=r2=-1 and ijklr = (ij)(kl)r = -1. This system is non-associative and non-alternative, but does meet the definition of a division algebra. The conversation also explores properties of this system, including its usefulness and the fact that it does not have zero-divisors.
EinsteinKreuz
64
So I have an interest in hypercomplex numbers and Clifford Algebras and was wondering a few months ago about other hypercomplex numbers besides the celebrated Quaternions and Octonions. I tried to construct a 5D complex number system using a Cayley table but noticed that entries in rows and columns were redundant. But what about a 6D complex number system? Well I managed to come up with a proposal using a Cayley table(and I do not claim to be the true originator) and here it is:
Now the rule to generate this Cayley table is i2=j2=k2=l2=r2=-1
And ijklr = (ij)(kl)r = -1
Now this is a non-associative algebra because (for example)
i((jk)(lr))= i(-rk) = i2 = -1
and (i(jk)(lr) = jk = -rHas anyone else seen an Algebra like this before? I googled "sextenions" and found one article from 11 years ago where it mentioned a 6D complex number system but did not present a Cayley multiplication table for it.
How do we know we are supposed to read ijklr as (ij)(kl)r?
(i(jk))(lr) = (i(-r))k = jk= -r
It is easy to come up with multiplication tables, but do you get useful properties from it?
They are not even alternative, a property octonions have.
You're right that they're neither associative nor alternative. Using the associator [x,y,z] = (xy)z-x(yz), we get
[i,j,k] = (ij)k-i(jk) = (k)k-i(-r) = k2+(ir=-j) = -(1+j)
[k,j,i] = (kj)i-k(ji) = j - k(-k) = j+k2 = -(1-j)
[i,k,j] = (ik)j-i(kj) = lj - (ir) = i+j
[k,i,j] = (ki)j - k(ij) = 1-i
[j,i,k] = (ji)k-j(ik) = 1+i
[j,k,i] = (jk)i - j(ki) = -(i+j)
And ∀(a,b,c,d,e,f,g,x,y,z,u,v,w)∈ℝ1(not all zero),
let S = a +(σ = bi+cj+dk+el+fr), T = x +(τ = yi+zj+uk+vl+wr)
S⊗T(the sextenion product) =
(ax)+(ay)i+(az)j+(au)k+(av)l+(aw)r
+ (bx)i -(by)+(bz)k+(bu)l -(bv)r -(bw)j
+ (cx)j -(cy)k -(cz) -(cu)r -(cv)i+(cw)l
+ (dx)k-(dy)l+(dz)r-(du)+(dv)j+(dw)i
+ (ex)l+(ey)r+(ez)i-(eu)j-(ev)+(ew)k
+ (fx)r+(fy)j-(fz)l-(fu)i-(fv)k-(fw)
= ax + xσ + aτ -(σ⋅τ) + σ◊τ
Where σ◊τ = (dw-cv+ez-fu)i +(dv-bw+fy-eu)j +(bz-cy+ew-fv)k +(bu-dy+cw-fz)l +(dz-bv+ey-cu)r .
Now ∀S(where S is a Sextenion), we define S* = a-bi-cj-dk-el-fr, so S⊗S* = (a2)-(ab)i-(ac)j-(ad)k-(ae)l-(af)r
+ (ab)i +(b2)-(bc)k-(bd)l +(be)r +(bf)j
+ (ac)j -(cb)k -(c2) +(cd)r +(ce)i+(cf)l
+ (ad)k+(db)l-(cd)r+(d2)-(de)j-(df)i
+ (ae)l-(be)r-(ce)i+(ed)j+(e2)-(ef)k
+ (af)r-(bf)j-(cf)l+(df)i+(ef)k-(f2)
= a2+b2+c2+d2+e2+f2Thus, if we define |S|2 = a2+b2+c2+d2+e2+f2,
then ∀S = a+bi+cj+dk+el+fr, [tex]S^{-1} = \frac{S^*}{|S|^2}[/tex] since
[tex]S ⊗ \frac{S^*}{|S|^2} = \frac{S^*}{|S|^2} ⊗ S = \frac{|S|^2}{|S|^2} = 1[/tex] . So the Sextenions are indeed a division algebra, which certainly is a useful property.
Nope--for ##S^-1## to have the form as described above, you would need ##[S*, S, x]## to vanish for all ##x##, which doesn't even hold for the basis elements.
Are you familiar with Hurwitz's theorem?
Come to think of it, Hurwitz's theorem isn't appropriate here. In any case, the existence of a two-sided inverse isn't strong enough to imply the division algebra property. The sedenions are an example of this.
The sedenions have zero-divisors. Haven't checked if the Sextenions do. In any case, according to the definition of a division algebra D:
∀a ∈ D & ∀(b≠0) ∈ D, ∃ Unique elements {x},{y} ∈ D such that a = bx & a = yb.
Now for a = i and b = k, i = k*r and i = -r*k so x = r and y = -r. You can check to see this holds for all pairs of basis elements. So the Sextenions are neither associative nor alternative but unlike the Sedenions they do (appear)to meet the definition of a division algebra.
And for all basis elements (i,j,k,l,r), the left and right product of each of these elements with its negative signed element = +1.
No division algebra has zero-divisors. This is a direct consequence of the definition for a=0 (as the elements x and y have to be unique, and x=0 and y=0 work).
Just because the basis elements form a loop doesn't mean that the algebra's collection of units does, as well.
All of the Cayley-Dickson loops are alternative, but the algebras associated with them have zero divisors beyond the octonions.
It's an important theorem about division algebras, proved only in the 1950s, that all division algebras over the reals must be of dimension 1, 2, 4, or 8. (It had already been known for several decades that the dimension has to be a power of 2.)
The usual examples are those created by the Cayley-Dickson doubling construction from the reals: the reals R, the complexes C, the quaternions H, and the octonions O.
It's often erroneously claimed that these are the only division algebras over R. That's not the case. Even in dimension 2 there exist division algebras that are not isomorphic to the complexes.
But if you toss in the extra condition that the division algebra must be normed — i.e., it must possesses a norm |⋅| with the property that
|xy| = |x| |y|
for all x, y in the division algebra, then indeed R, C, H, and O are the only normed real division algebras. (Likewise if the division algebras are required to be alternative, as suggested above, these four are the only examples.)
Likes suremarc
|xy| = |x| |y|
Where did the normed property come into play and have you tested to see whether or not the Algebra I proposed satisfies this property?
I will be happy to do so when I have a bit more time(as it's going to be very, very messy since each Sextenion has 6 terms! :-p)
By the first theorem I quoted, any real algebra not of dimension 1, 2, 4, or 8 will necessarily have zero-divisors, i.e., two nonzero elements x, y such that
xy = 0.​
If this algebra were a normed algebra with |⋅|, we would have
|xy| = |x| |y|.​
But an element has norm 0 if and only if it is the zero element. Hence this would lead to a contradiction.
Related to Sextenions (6D hypercomplex numbers)
1. What are Sextenions?
Sextenions are a type of hypercomplex number, meaning they extend the concept of traditional numbers (real, complex, and quaternion) by adding more dimensions. They are also known as 6D numbers because they have six components.
2. How are Sextenions different from other hypercomplex numbers?
Sextenions are unique in that they have six components, while other hypercomplex numbers have less (real numbers have one, complex numbers have two, and quaternions have four components). This allows for more complex mathematical operations and applications in fields such as physics and engineering.
3. What are some real-world applications of Sextenions?
Sextenions have been used in physics to describe the behavior of particles such as fermions and bosons. They have also been applied in computer graphics and robotics for motion planning and control. In mathematics, they have been used to study higher-dimensional spaces and geometric transformations.
4. How do you perform operations with Sextenions?
Similar to other hypercomplex numbers, Sextenions follow specific rules for addition, multiplication, and division. For example, to add two Sextenions, you would add the corresponding components together. Multiplying two Sextenions involves a more complex process, but it ultimately results in a new Sextenion with six components.
5. Are there any limitations to using Sextenions in calculations?
As with any mathematical concept, there are limitations to using Sextenions. One limitation is that they are not commutative, meaning the order in which you multiply them affects the result. This can make calculations more complex. Additionally, they may not have all the properties of traditional numbers, such as a defined order or the ability to take square roots.
  • Linear and Abstract Algebra
  • Beyond the Standard Models
  • General Math
  • General Math
