Sharing a birthday - what's wrong in my approach?
  • Thread starter musicgold
  • Tags
    Approach
In summary: However, it remains correct for larger groups.In summary, the probability of a shared birthday is about 0.008204.
musicgold
304
This is not really a homework problem. This is something I enjoy thinking about.
1. Homework Statement
How many people should there be in a group to have a 50% chance of at least two of them having the same birthday.
I know that there a many pages explaining how to solve this and the answer itself. But I wanted to develop my own way to figure this out.
The problem boils down to how many unique pairs or handshakes can be formed in the group. That is N x (N-1) / 2 .
Also, the probability that a pair has the same birthday is 1/365.
Therefore, I think I have solve the following equation for N
N x (N-1) = 365
The approximate value of N is 20. For N=20, I think the probability of having at least one pair with the same birthday is 52%. But according this Wikipedia page there has to be 23 people for a 50% probability in this case.
Clearly I am doing something wrong. Maybe assigning the 1/365 probability to every pair is not correct. I don't know.
You can't add probabilities like that. Try to use the same approach to find when there is certainly a shared birthday and the problem should become obvious.
Similarly: 3 die rolls don't give you a 50% probability to roll a 1. The probability is a bit lower.
You calculated the number of people where we have on average 1/2 shared birthday.
N x (N-1) = 365
The usual birthday problem looks at more than "pairs"; it asks for the probability that at least two people share a common birthday; perhaps three, or four, or more people share that same birthday. It does so by looking at the probability of no common birthdays, then taking its complement.
The problem of computing the probability that exactly one pair share a birthday (and no others do) is much harder.
N x (N-1) = 365
Your method is an approximation for low probabilities. Let's take an example of 3 people, A, B, C. What is the probability of a shared birthday?
Your method is:
Probability A & B share a birthday = 1/365
Probability A & C share a birthday = 1/365
Probability B & C share a birthday = 1/365
So, total probability is 3/365 = 0.008219
But, that's only an approximation to the correct answer, which is
Probability A & B do not share a birthday = 364/365
Probability that C does not share a birthday with A & B (given that A & B do not share a birthday) = 363/365
Probability that A, B, C all have different birthdays = (364/365)(363/365).
Probability that there is a shared birthday = 1 - (364/365)(363/365) = 0.008204
As you increase the number of people, the approximation becomes less accurate (as you've discovered for about 20 people).
FAQ: Sharing a birthday - what's wrong in my approach?
What is "Sharing a Birthday" and why is it important in scientific research?
"Sharing a Birthday" is a phenomenon where two or more individuals in a group have the same birthdate. It is important in scientific research because it helps to understand the probability of this occurrence and how it can be applied in different fields such as statistics, genetics, and social sciences.
What is the traditional approach to calculate the probability of sharing a birthday in a group of people?
The traditional approach is to use the birthday problem formula, which states that the probability of at least two individuals sharing a birthday in a group of n people is 1 - (365!/((365-n)!*365^n)).
What are the limitations of the traditional approach in calculating the probability of sharing a birthday?
The traditional approach assumes that birthdays are equally likely to occur throughout the year, which is not always true. It also does not take into account leap years, and it does not consider the fact that some people may share the same birth year.
What are some alternative approaches to calculate the probability of sharing a birthday?
Some alternative approaches include using a simulation method, where random birthdates are generated and compared to see if there are any matches. Another approach is to use a more advanced formula, such as the Poisson approximation or the Inclusion-Exclusion principle.
How can the concept of "Sharing a Birthday" be applied in real-life situations?
The concept of "Sharing a Birthday" can be applied in various fields, such as predicting the likelihood of two people in a group having the same birthday, analyzing patterns in social networks, and determining genetic similarities between individuals. It can also be used in event planning and scheduling to avoid conflicts and overlaps.
