zack7
- 55
The moment and shear flow equations
Solved with Matlab
I am getting real close to the answer but something is off and I can't figure it out.
The full code (Matlab)
Code:
deg = pi/180;
G = 4.e6;
%...Flange areas (in^2):
Af = [1 0.5 0.5 1 1 0.5 0.5 1];
nstringers = length(Af);
%...Flange coordinates (in):
z = [ 0 6 14 24 24 14 6 0];
y = [ 0 0 0 0 10 10 10 10];
%...Wall thicknesses (in):
t = [0.04 0.04 0.04 0.05 0.04 0.04 0.04 0.05 0.025 0.025];
npanels = length(t);
%...Wall connectivity:
node = [1 2
2 3
3 4
4 5
5 6
6 7
7 8
8 1
7 2
6 3];
%...Wall lengths:
for i = 1:npanels
s(i) = norm([y(node(i,2)) - y(node(i,1)) z(node(i,2)) - z(node(i,1))]);
end
%...Locate the centroid:
zG = sum(z.*Af)/sum(Af);
yG = sum(y.*Af)/sum(Af);
%...Compute the centroidal moments of inertia:
Iy = sum(Af.*(z - zG).^2);
Iz = sum(Af.*(y - yG).^2);
Iyz = sum(Af.*(y - yG).*(z - zG));
%...Flange load gradients, Equation [4.8.2]:
syms Vy Vz
dPdx = 1/(Iy*Iz - Iyz^2)...
*( (Iy*Vy - Iyz*Vz)*(y - yG)...
+(Iz*Vz - Iyz*Vy)*(z - zG)).*Af;
%...Stringer equilibrium at flanges 1 through 7:
syms q1 q2 q3 q4 q5 q6 q7 q8 q9 q10
eq1 = q1 - q8 - dPdx(1);
eq2 = q2 - q1 - q9 - dPdx(2);
eq3 = q3 - q2 - q10 - dPdx(3);
eq4 = q4 - q3 - dPdx(4);
eq5 = q5 - q4 - dPdx(5);
eq6 = q6 - q5 + q10 - dPdx(6);
eq7 = q7 - q6 + q9 - dPdx(7);
%...Moment equivalence about flange 8, including dummy torque T:
syms T
A1 = 1/2*s(1)*s(8);
A2 = 1/2*s(2)*s(8);
A3 = 1/2*s(3)*s(8);
A4 = 1/2*s(4)*(s(1) + s(2) + s(3));
A9 = 1/2*s(9)*s(1);
A10 = 1/2*s(10)*(s(1) + s(3));
eq8 = 2*A1*q1 + 2*A2*q2 + 2*A3*q3 + 2*A4*q4 - 2*A9*q9 - 2*A10*q10 - ...
(-Vy*14 - Vz*0) - T;
%...Solve the above eight equations for the shear flows q1 through q8
% in terms of the redundants q9 & q10, the applied loads Vy & Vz and
% the dummy torque T:
solution = solve(eq1,eq2,eq3,eq4,eq5,eq6,eq7,eq8, ...
q1, q2, q3, q4, q5, q6, q7, q8);
%...Store the results (Equations [f] of the text) in the vector 'q':
q = [solution.q1 solution.q2 solution.q3 solution.q4 ...
solution.q5 solution.q6 solution.q7 solution.q8 ...
q9 q10];
%...Obtain the virtual shear flows from the actual ones by zeroing the
% applied loads and replacing the true redundant shear flows by
% their virtual counterparts and the dummy torque T by the virtual
% torque dT:
syms dq9 dq10 dT
dq = subs(q, {q9 q10 Vy Vz T}, {dq9 dq10 0 0 dT});
%...Substitute the values of the external loads into the shear flow
% expressions:
q = subs(q, {Vy Vz T}, {-8000 0 0});
%...Calculate the internal complementary virtual work:
syms L
dWint = -L/G*sum(s./t.*q.*dq);
%...The external complementary virtual work:
syms theta
dWext = theta*dT;
%...PCVW:
dW = dWint + dWext;
%...This results in an equation of the form c1*dq9 + c2*dq10 + c3*dT = 0.
% Isolate c1, c2 and c3:
c1 = subs(dW, {dq9 dq10 dT}, {1 0 0});
c2 = subs(dW, {dq9 dq10 dT}, {0 1 0});
c3 = subs(dW, {dq9 dq10 dT}, {0 0 1});
%...Solve these three equations for q9, q10 and theta:
solution = solve(c1, c2, c3, q9, q10, theta);
%...Substitute the shear flow results into the expressions for
% q1 through q8:
q = subs(q,{q9 q10},{solution.q9 solution.q10});
theta = solution.theta;
fprintf('\n----------------------------------------------------\n')
disp(probTitle)
fprintf('\n %s\n %s\n\n', programmer, date)
disp(probStatement)
fprintf('\n Flange z(in) y(in) A(in^2)')
for i = 1:8
fprintf('\n %4.0f %8.2f %8.2f %8.2f',i,z(i),y(i),Af(i))
end
fprintf('\n\n Wall Thickness(in) Length(in)')
for i = 1:10
fprintf('\n%4.0f %8.2f %8.4f',i,t(i),s(i))
end
fprintf('\n\n Centroid coordinates (in.)')
fprintf('\n zG = %g yG = %g \n', zG, yG)
fprintf('\n Moments of inertia (in.^4):')
fprintf('\n IGz = %g IGy = %g IGyz = %g \n', Iz, Iy, Iyz)
fprintf('\n Shear loads:')
fprintf('\n Vy = -8000 lb Vz = 0 lb \n')
fprintf('\n Shear flows (lb/in):\n')
for i = 1:10
fprintf(' q%g = %10.4f\n', i, double(q(i)))
end
fprintf('\n Angle of twist:')
fprintf('\n theta/L = %g degrees/in', double(theta/deg/L))
fprintf('\n----------------------------------------------------\n\n')
