Shear rate in rectangular "channel"
In summary, the conversation discusses the calculation of shear rate in a rectangular channel for simulating blood flow conditions. The average wall shear rate is given by a formula involving the volumetric throughput rate, cross sectional area, wetted perimeter, and a shape factor. The conversation also considers the use of a mix of materials in the channel and potential errors in calculations. Cited papers provide further information on blood flow volume quantification and differences in wall shear rates in different arteries. After correcting for units, the calculated volumetric throughput rate seems plausible.
Ekaekto
Hi everyone,
Non-physics student here, and slightly in over my head :D
I am slightly stumped for ideas regarding the calculation of the shear rate in a rectangular type channel, which I need to effectively simulate a blood flow type condition in a channel that has to be rectangular due to the specimen that I am testing.
Of course I could just go ahead and use velocity as the only measure, but it seems to me to be better if I had the shear rate and could compare that to blood flow.
The channel that I have is 10 mm wide, 2 mm high (and 90 mm long). The velocity can be changed at will, the maximum I can reach (but don't want to, it's too high :D) is 0.7 m/s. How would I calculate this correctly? Do I need to use Stokes equation or am I thinking too complicated?
Another problem that arises is that I have a mix of materials in this channel, because it is basically plates screwed together with a silicone seal in the middle. The bottom of the channel is made from stainless steel, the sides of the channel are made from silicone and the top is made from PP.
Would it make sense to approximate having a homogenous material? The most important area (where the test specimen is placed) is the stainless steel bottom, so would it make sense to assume stainless steel everywhere?
Thanks for the help :)
Likes Deacon James
You have axial fluid flow down a rectangular channel, and you would like to know the shear rate at the wall, correct?
Likes Deacon James
Yes, its fully developed laminar flow. That far I have managed to calculate :)
If possible it would be best for me to know how the shear rate behaves across the cross section, however at the walls would suffice also, as the shear rate for blood that is usually found (edit: in literature) is also given as the one at the wall (I'd guess because it's non-Newtonian). So if I wish to use a similar shear rate, I'd really only need the one at the wall.
If there's any type of publication on the topic that would also be of help, I can try understanding it myself, calculating and coming back if any questions come up
Likes Deacon James
For a rectangular channel, the average wall shear rate is given by $$\gamma=\frac{QP\lambda}{8A^2}$$where Q is the volumetric throughput rate, A is the cross sectional area of the channel and P is the wetted perimeter, and where the shape factor ##\lambda## is given by:$$\lambda=\left[(1-0.351b/a)(1+b/a)\right]^2$$with b representing the short side of the rectangle and a representing the long side.
For more details on this, see "Predicting Non-Newtonian Flow Behavior in Ducts of Unusual Cross Section," Miller, C., Industrial and Engineering Chemistry Fundamentals, 11, 1972, pages 524-528.
Thank you very much! That's a great help!
After calculating, the ##Q## I am getting seems rather small to me.
I based the calculation on the wall shear rate of the carotid artery that is ##γ = 333,3 s^{-1}##
##a = 0.0104 m## and ##b = 0.002 m##
So, ##A^2 = 4.3264*10^{-10} m^2##
##λ = 1.253##
##P = 0.0248 m ## (as the entire channel is wetted, I calculated a regular ##2a+2b## - is this assumption correct?)
So when solving for ##Q ## I would get the following formula: $$Q = \frac {8A^2γ} {Pλ},$$
and adding in all calculated numbers and SI-Units I reached the following conclusion: $$Q = \frac {8*4.3264*10^{-10}m^2*333.3s^{-1}} {0.0248m*1.253} = 3,71*10^{-5} \frac {m} {s},$$
Does that seem plausible? Are the SI-units even correct? I always thought ##Q## is given as ##\frac {m^3}{s}## but I got ##\frac {m}{s}##. It seems very slow to me, for my specific cross-section it would mean using a volumetric flow slower than the one I have currently, which is already rather small at ##800 µL/min = 1.333333333336*10^{-8} \frac{m^3}{s}## which yields a velocity of ##9*10^{-4}\frac{m}{s}## at the point of interest.
I probably have a slight misconception here, because I am comparing it with the volumetric flow rate of blood through the carotid artery which is much higher at ##238.84 \frac {mL}{min} = 3.981 \frac{m^3}{s}##
There's probably some mistake in my calculation that I am missing.
Cited papers:
S.O. Oktar, C. Yücel, D. Karaosmanoglu, K. Akkan, H. Ozdemir, N. Tokgoz, T. Tali (2006) Blood-Flow Volume Quantification in Internal Carotid and Vertebral Arteries: Comparison of 3 Different Ultrasound Techniques with Phase-Contrast MR Imaging American Journal of Neuroradiology Feb , 27 (2) 363-369
Wu, S. P., Ringgaard, S. , Oyre, S. , Hansen, M. S., Rasmus, S. and Pedersen, E. M. (2004), Wall shear rates differ between the normal carotid, femoral, and brachial arteries: An in vivo MRI study. J. Magn. Reson. Imaging, 19: 188-193. doi:10.1002/jmri.10441
In your below calculation the units for A^2 should be m^4 not m^2 and that will result in m^3/s which resolves your units issue for Q
Ekaekto said:
Q=8A2γPλ,Q=8A2γPλ,​
Q=8∗4.3264∗10−10m2∗333.3s−10.0248m∗1.253=3,71∗10−5ms,​
Likes Ekaekto
D'oh, that was daft of me. Thanks :)
Ok, but then I see no other issue with the calculation...other than intuitively it seems very small to me. But science doesn't care about intuition I suppose :D
$$238.84\ mL/min=3.981\ mL/s = 3.981\times 10^{-3}\ m^3/s$$If the carotid artery were a circular tube with this volumetric flow rate, and the shear rate in the tube were 333.3 1/s, I would calculate a value of the tube diameter of 0.5 cm (using a value of ##\lambda=16## for a circular tube).
I'm very sorry. In my post #4, I gave you the wrong equation for ##\lambda##. The correct equation is:
$$\lambda=\frac{24}{\left[(1-0.351b/a)(1+b/a)\right]^2}$$
With this equation, for your geometry, b/a = 0.192, I calculate ##\lambda=19.4##. Now, using the equation I gave with the correct value of ##\lambda## would yield a flow rate of 2.4 cc/sec with a shear rate of 333.3 1/s. So this is comparable to the value of 4 cc/sec you gave for a carotid artery.
Oh yes, I also made a mistake above leaving out the ##10^{-3}## for the volumetric flow in a blood vessel. I just forgot it when typing up my manual notes.
Now it all makes more sense :)
Related to Shear rate in rectangular "channel"
1. What is shear rate in a rectangular channel?
Shear rate in a rectangular channel refers to the change in velocity of a fluid as it flows through a rectangular channel. It is a measure of the fluid's deformation or strain rate due to the applied shear stress.
2. How is shear rate calculated in a rectangular channel?
Shear rate in a rectangular channel can be calculated by dividing the velocity gradient by the distance between the two walls of the channel. It can also be calculated by multiplying the flow rate by the channel's hydraulic diameter.
3. What factors affect shear rate in a rectangular channel?
The shear rate in a rectangular channel is affected by the fluid's viscosity, the velocity of the flow, and the channel's dimensions. The roughness of the channel walls and the presence of any obstacles can also affect the shear rate.
4. Why is shear rate important in a rectangular channel?
Shear rate is an important parameter to consider in a rectangular channel as it affects the flow behavior of the fluid. It can indicate the potential for turbulence, mixing, and heat transfer within the channel, and can also impact the performance of any equipment or processes that rely on fluid flow.
5. How can shear rate be controlled in a rectangular channel?
Shear rate in a rectangular channel can be controlled by adjusting the flow rate, changing the channel dimensions, or altering the viscosity of the fluid. Adding flow modifiers or using different channel materials can also help to control the shear rate.
  • Classical Physics
  • Materials and Chemical Engineering
  • General Engineering
  • DIY Projects
