Sheet of charge - theory
When thickness is not specified for a plate, it is generally considered infinitely thin or arbitrarily thin for calculations. For a sheet of charge, the area used in the formula sigma=Q/A should account for both sides if Q represents the total charge. In the case of parallel plates with opposite charges, the area considered is typically that of one side where the charge resides. The Gaussian surface area does not need to be halved; it should reflect the area where the electric field is relevant. Charge distribution on a capacitor only considers the surface area, not the volume, as the surface area ratio is what matters for charge distribution.
Iamconfused123
EA=Q/Eo, Sigma=Q/A, E=kQ/r^2
To some of these questions I can't find answers on the internet and to some I assume what the answer is but I'd still like to get a confirmation.
When I am not given the thickness of the plate, does that mean that the plate is intinitely thin?
What is the area of the sheet of charge when the sheet stands alone when we calculate sigma=Q/A, is it the surface area of both sides of the sheet or just one side?
What is the area in sigma=Q/A when we have a plate next to another parallel plate of opposite charge ( I assume for this one area to be only one side, but still)? In this case what area do we put in formla for Gaussian surface (EA=Q/Eo), because when two plates of opposite charges are next to each other then positive and negative charges on the same plate separate and the extra (for example of positive charge) eminate field only to the right, for example (or do they, I am not sure about this one), so should the area of the Gaussian surface be halved as well?
How does charge distribute itself over infinitely thin sheet? Is area for sigma=Q/A here only one side or both sides?
If charge does not reside IN the conductor but only on the outer surface, do we take only the surace area into account for charge distribution of the capacitor or do we care about volume?
Thank you very much.
Either arbitrarily thin or, for the question asked, the thickness won't matter.
If Q is the whole charge and ##\sigma## is the density on each side then A is the total area for the two sides.
If the arrangement ensures all the charge is on the same side then clearly A is just the area of that side.
I'm not sure I have understood the situation. Please give a specific example.
No sheet is infinitely thin. It can be arbitrarily thin.
Not volume, which would be the product of surface area and plate separation. Instead, it is the ratio of the two that matters.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
