Shell and Tube Exchanger Design Problem
In summary: These changes will result in a smaller overall heat transfer area, which will reduce the length of the tube. In summary, in this problem, a heat exchanger needs to be designed to cool caustic soda from 190℉ to 120℉ using water at 80℉. The specific heat and viscosity of the fluids are given, and the design parameters include a combined dirt factor, pressure drops, and tube length. The tube side fluid should be caustic soda and the shell side fluid should be water. For estimating the overall heat transfer coefficient, the film heat transfer coefficients should be taken to be 0.5 Btu/hr-ft2-°F for caustic soda and 0.25 Btu/hr
AAMAIK
47
51300 kg/hr caustic soda (= 1.115, = 0.349 Btu/lb ∙ ℉ ∙ ft) leaves a dissolver at 190℉ is to be cooled to 120℉ using water at 80℉ which will be heated to 120℉. Knowing that the specific heat and the viscosity at the mean of 0.88 Btu/lb ∙ ℉ and 0.76 cp respectively. Plant practice permits the use of 1.25 in triangular pitch with 1 in OD, 16 ft tube length, 14 BWG. Use a combined dirt factor of 0.002 and pressure drops of 10 psi. Design a suitable heat exchanger.
I used the basic design procedure in Lecture 7 B as a guide to design the HE.
Which fluid is the tube side fluid and which is the shell side fluid, if caustic soda is more corrosive than water and it has a smaller flow rate than water?
To estimate the value of the overall heat transfer coefficients for preliminary analysis, what values for the film heat transfer coefficients should I take for the caustic soda if it contains 11 % NaOH and water?
What changes in the design parameters should I consider when redesigning the Shell and tube HE if the calculated length of the tube is larger than the given tube length (6.81 m > 4.87 m)?
New Doc 2018-11-24 04.24.39.pdf Contains images of my attempt at solving the problem
  • Lecture 7B.pdf
  • New Doc 2018-11-24 04.24.39.pdf
.For the first question, the caustic soda should be the tube side fluid and the water should be the shell side fluid. This is because the caustic soda is more corrosive than water and has a smaller flow rate. For the second question, the overall heat transfer coefficient can be estimated by using the following formula: U=1/((1/hc)+(R/k)+ (1/ho)). Where hc is the convection heat transfer coefficient of the tube side, R is the thermal resistance of the tube wall, and ho is the convection heat transfer coefficient of the shell side. For the caustic soda, the film heat transfer coefficient should be taken to be 0.5 Btu/hr-ft2-°F and for the water it should be taken to be 0.25 Btu/hr-ft2-°F.For the third question, if the calculated length of the tube is larger than the given tube length, then the design parameters should be changed to reduce the tube length. This can be done by increasing the number of tubes, reducing the tube diameter, or increasing the pitch to tube diameter ratio.
FAQ: Shell and Tube Exchanger Design Problem
1. What is a shell and tube exchanger?
A shell and tube exchanger is a type of heat exchanger that is used to transfer heat between two fluids. It consists of a large cylindrical shell with a bundle of smaller tubes inside. One fluid flows through the tubes while the other flows around the outside of the tubes, allowing for heat transfer between the two fluids.
2. What factors affect the design of a shell and tube exchanger?
The design of a shell and tube exchanger is affected by several factors, including the type and properties of the fluids being used, the desired heat transfer rate, the available space and materials, and the overall cost and efficiency goals.
3. How is the heat transfer area determined in a shell and tube exchanger?
The heat transfer area in a shell and tube exchanger is determined by calculating the total surface area of the tubes and the shell, which is based on the number and length of the tubes, as well as the diameter and length of the shell. The heat transfer coefficient of the fluids is also taken into account in this calculation.
4. What is the purpose of baffles in a shell and tube exchanger?
Baffles are used in a shell and tube exchanger to direct the flow of the fluids and increase turbulence, which enhances the heat transfer rate. They also help to prevent the tubes from sagging under high pressure or flow rates.
5. How can the performance of a shell and tube exchanger be improved?
The performance of a shell and tube exchanger can be improved by increasing the surface area of the tubes and shell, using baffles to enhance turbulence, and choosing materials with high heat transfer coefficients. Regular maintenance and cleaning of the exchanger can also help to improve its efficiency and performance.
