Shell method about the line x=5
In summary, the volume of an arbitrary shell is:dV=2\pi rh\,dxNext, you want to sum all the shells:V=2\pi\int_0^4 (5-x)\left(4x-x^2 \right)\,dx
alane1994
36
I have been going over previous tests in an attempt to better prepare myself for the final that is coming tomorrow. I was posed a question.
Use the shell method to find the volume of the solid generated by revolving the plane region about the given line.
\(\displaystyle y = 4x - x^2\)
, y = 0, about the line x = 5
I know this.
SHELL METHOD
\(\displaystyle V = \int_{a}^{b} 2\pi x (f(x) - g(x))dx\)
I know this is fairly rudimentary, but assistance would be appreciated!
The volume of an arbitrary shell is:
\(\displaystyle dV=2\pi rh\,dx\)
What are $r$ and $h$?
Ok, is "h" the highest point of the graph?
And if so, r would be 5-x, where x is the corresponding coordinate for the highest point?
No, $h$ is the distance from the top curve to the bottom curve at the value of $x$ for the arbitrary shell. The arbitrary shell can be anywhere for $0\le x\le4$. I just drew one such shell.
So we have:
\(\displaystyle r=5-x\)
\(\displaystyle h=\left(4x-x^2 \right)-0=4x-x^2\)
and thus the volume of the shell is:
\(\displaystyle dV=2\pi(5-x)\left(4x-x^2 \right)\,dx\)
\(\displaystyle V=2\pi\int_0^4 (5-x)\left(4x-x^2 \right)\,dx\)
I know this.
SHELL METHOD
With the substitution $\xi= 5 - x$ You have to compute the volume of the rotation solid about $\xi=0$ of the function $\displaystyle f(\xi) = - 5 + 6 \xi - \xi^{2}$ obtaining... $\displaystyle V = 2\ \pi\ \int_{1}^{5} \xi\ (- 5 + 6 \xi - \xi^{2})\ d \xi = 64\ \pi\ (1)$
Kind regards
$\chi$ $\sigma$
THAT'S MY PROBLEM!
I had
\(\displaystyle V = \int_{0}^{4} 2\pi x ((x-5) - (4x-x^2))dx\)
That is where I got off. You need to change the x into 5-x.
\(\displaystyle V = \int_{0}^{4} 2\pi (5-x)(4x-x^2)dx\)
alane1994 said:
THAT'S MY PROBLEM!
I had
You can't get from the first formula to the second simply by replacing $x$ with $5-x$.
The formula you cited in your original post looks like it was meant for revolution about the $y$-axis. I find it easier to not try to use such a formula, but to just look at one element of the entire volume, whether it be a shell, disk or washer. Once you have the elemental volume, then you can add all the elements by integrating.
Another picture:
Ok, I have arrived at an answer of \(\displaystyle 64\pi\).
FAQ: Shell method about the line x=5
What is the Shell Method about the line x=5?
The Shell Method is a mathematical technique used to calculate the volume of a solid of revolution when the axis of rotation is a line parallel to the y-axis, such as x=5. It involves slicing the solid into thin cylindrical shells and integrating their volumes.
How do you set up the Shell Method for x=5?
To set up the Shell Method for x=5, you need to first draw a cross-section of the solid and identify the axis of rotation, which is the line x=5. Then, choose a representative shell and find its radius and height in terms of x. Finally, integrate the volume formula, 2𝜋rh, from the lower bound to the upper bound of x.
What is the formula for calculating volume using the Shell Method for x=5?
The formula for calculating volume using the Shell Method for x=5 is V = 2𝜋∫abxf(x)dx, where a and b are the lower and upper bounds of x and f(x) is the function that gives the radius and height of the representative shell.
What are the advantages of using the Shell Method for x=5 over other methods?
One advantage of using the Shell Method for x=5 is that it can be used to find the volume of solids with irregular shapes, such as those with holes or curves. It also often requires less calculation and is more intuitive compared to other methods, such as the Disk Method or Washer Method.
What are some real-life applications of the Shell Method for x=5?
The Shell Method for x=5 has many real-life applications, such as calculating the volume of a soda can, a vase, or a water tower. It can also be used in engineering and architecture to determine the volume of objects with complex shapes, such as pipes, columns, or beams.
