Shift Phase of 100 kHz Signal 90 Degrees
In summary, the individual is seeking advice for building a circuit to shift the phase of a 100 kHz sine wave by 90 degrees. They have tried using passive integrators and differentiators, as well as op-amp integrators and differentiators, but have not been successful. They are wondering if anyone has tips or pointers for a simple circuit. Some suggestions include using an R-C integrator with a long time constant, cascading three 30 degree shifts, or using an active integrator. They are also considering using a phase-locked loop IC or an all-pass filter. They are also curious about low-powered oscillator configurations for the 100 kHz signal. Their end goal is to use a QAM signal for two audio channels,
  • #36
Very first post said
For a school project I need to be able to shift the phase of a 100 kHz sine wave by 90 degrees (either positive or negative).
Has this been mentioned ? i wonder if a "bucket brigade" analog delay line device might be a useful mix of analog and digital technology for that task. Clock could be pll to a multiple of the incoming sinewave thereby avoiding frequency dependence of analog RC filters.
http://www.datasheetarchive.com/dl/Scans-091/DSAHI00040423.pdf
  • #37
Then in post #7, the final application was specified.
Does you application demand the accuracy & stability of a crystal oscillator?
On that note, what is your application that it needs quadrature signals?
The end product will use a QAM signal to send two audio channels, and the device will need to be very small and low-powered so an LC oscillator would be too bulky. Other oscillators based on ceramic resonators could work, but the principal would be the same as a crystal oscillator I think, which is proving to be very difficult to design.
We do not know the exact wording of the original project specification.
  • #38
This has been a fun and interesting thread, but I have to confess that I haven't read all the posts in detail, so apologies if this solution has already been covered.
The way I've done this in the past is to use 2 ROMs with sine wave data in them that is offset by 90 degrees (for I and Q demod, but the technique works for encode as well). They are clocked together, and their outputs are driving R-2R ladder DACs with filter buffers. This gives you 2 very nice sine waves that are 90 degrees out of phase.
You can then use those waveforms for your 4QAM modulation circuit.
Works great with I and Q always separated 90deg even in unit number one million. The quantization noise is down 2^2b from the carrier power or, say, 48dB w 8 bits meaning, I think, that an analog osc is still required to realize very high SNR.
  • Electrical Engineering
