Shifting the position of an equilbrium
  • Thread starter Moogie
  • Tags
    Position
In summary, at equilibrium, the ratio of products to reactants is constant and the rates of the forward and reverse reactions are equal. When the equilibrium is disturbed, the position shifts to consume more reactants and produce more products to restore the equilibrium ratio. The rates of the reactions may be different during this time, but once the new equilibrium is reached, the rates will be equal again. The position of the equilibrium refers to the specific ratio of products/reactants that equals the equilibrium constant, and shifting the equilibrium to the right or left changes this ratio.
Moogie
168
Hi
At equilibrium there is a constant ratio of products to reactants and the rates of the forward and back reactions are the same.
When you distrub the equilibrium by say adding more reactants the equilibrium position shifts to the right so as to consume more reactants and produce more products to restore the equilibrium ratio.
Question 1
During this time of readjustment the rates of the forward and back reactions are the different, but once the new equilibrium position has been attained the rates of reaction of the forward and reverse reactions will once again be equal but will they be the same rates that they were before? In theory they could be slower or faster?
Question 2
Does the 'position of the equilibrium' refer to the specific ratio of products/reactants that equals the equilibrium constant? So if you are shifting the equilibrium to the right you are increasing the product concentration and decreasing the reactant concentration in this ration? If you are shifting the equilibrium to the left you are doing the reverse
thanks
Chemistry news on Phys.org
Answer 1: Yes, the rates of the forward and reverse reactions will be equal once the equilibrium is re-established, but they may be different than the original rates. The rate of reaction is determined by the concentration of reactants and products, so if the concentrations are different, the rate of reaction will also be different. Answer 2: Yes, the position of the equilibrium refers to the ratio of products/reactants that equals the equilibrium constant. If you shift the equilibrium to the right, you are increasing the product concentration and decreasing the reactant concentration in this ratio. If you shift the equilibrium to the left, you are doing the reverse.
Related to Shifting the position of an equilbrium
1. What is meant by shifting the position of an equilibrium?
Shifting the position of an equilibrium refers to the movement of the equilibrium point in a chemical reaction, which occurs when the concentrations of reactants and products change. This can happen due to changes in temperature, pressure, or the addition/removal of reactants or products.
2. How does changing the temperature affect the equilibrium position?
According to Le Chatelier's Principle, an increase in temperature will cause an equilibrium position to shift in the direction of the endothermic reaction (one that absorbs heat). Conversely, a decrease in temperature will shift the equilibrium towards the exothermic reaction (one that releases heat).
3. Can the pressure affect the equilibrium position?
Yes, changes in pressure can also shift the equilibrium position. For reactions involving gases, an increase in pressure will shift the equilibrium towards the side with fewer gas molecules, while a decrease in pressure will shift it towards the side with more gas molecules.
4. What is the effect of adding a reactant on the equilibrium position?
Adding a reactant will cause the equilibrium position to shift towards the products, as the increased concentration of the reactant will drive the reaction in that direction. Similarly, removing a reactant will shift the equilibrium towards the reactants.
5. How do catalysts affect the equilibrium position?
Catalysts do not affect the equilibrium position, as they speed up both the forward and reverse reactions equally. However, they can help the reaction reach equilibrium faster by lowering the activation energy, but they do not shift the equilibrium position itself.
  • Chemistry
