SHM Energy Conservation in a Spring
In summary, the energy conversions in a spring undergoing simple harmonic motion can be described as follows: at the point of maximum compression, all of the potential energy stored in the spring is converted into kinetic energy, resulting in maximum speed. As the spring moves towards the equilibrium point, the kinetic energy is gradually converted back into potential energy, causing the speed to decrease until it reaches a minimum at the point of maximum stretch. At this point, there is no kinetic energy and the spring is at rest momentarily. As the spring moves back towards the equilibrium point, the potential energy is again converted into kinetic energy, resulting in an increase in speed until it reaches a maximum at the equilibrium point. From there, the cycle repeats itself, with the spring moving back
emxlys
1. The problem statement, all variables, and given/known data
Describe the energy conversions in a spring undergoing simple harmonic motion as it moves from the point of maximum compression to maximum stretch in a frictionless environment. Focus on points at which there will be maximum speed, minimum speed, minimum acceleration.
b) Explain what is meant by damping, give an example of a technology that requires a damping mechanism and describe how it takes place.
The attempt at a solution
i) Maximum speed.
The maximum speed of an oscillating spring would be when it is at the equilibrium. At this point all the gravitational energy would be converted to kinetic energy.ii) Minimum speed.
The speed of an oscillating spring would be minimum at two places, the max compression and when the spring has reached it max stretch. At these points there would be no kinetic energy.iii) Minimum acceleration.
Acceleration is at its minimum when at equilibrium.a) Dampening is a decrease in the amplitude of oscillation until it decreases to 0. This is usually due to forces such as air resistance and friction. An example of dampening is in the tower Taipei 101. This tower is known as the Taipei World Financial Center. This is where the largest tuned mass damper is located. This stabilizes the building and protects it from violent motion. This violent motion is usually due to environmental forces such as earthquakes. Another example we could use is a piano, or more specifically the grand piano. Basically, when you press and hold on a key it causes a hammer to transfer all that energy to a string which vibrates and causes the damper to be lifted and this causes the string to continue oscillating until it slowly comes to a stop. If you simply press and let, go of the key right away the damper will take the energy away from the note giving it less time to oscillate. There’s even a “damper” pedal on a piano that would actually lift the dampers and allow the note to be drawn out longer.
Thank you!
Hello em,
What is your question ? Do you want an approval stamp from PF (not really our business :smile: ) ?
BvU said:
Hello em,
I wanted to make sure if this is the correct answer or know if I am doing something wrong.
Gravity does not feature in this question.
Seems to me the form of answer sought is a narrative describing the motion through one cycle, mentioning the points of min speed, min acceleration and max speed along the way.
FAQ: SHM Energy Conservation in a Spring
What is SHM energy conservation in a spring?
SHM energy conservation in a spring refers to the principle that in a simple harmonic motion (SHM) system, the total mechanical energy (sum of kinetic and potential energies) remains constant throughout the motion.
How does energy conservation apply to a spring?
In a spring, the potential energy is stored in the form of elastic potential energy due to the deformation of the spring. As the spring oscillates back and forth, the potential energy is converted to kinetic energy and vice versa, resulting in a constant total energy.
What is the equation for calculating the total energy in SHM?
The equation for calculating the total energy in SHM is E = 1/2kA^2, where E is the total energy, k is the spring constant, and A is the amplitude of the oscillation.
Does the total energy change in SHM?
No, the total energy in SHM remains constant as long as there are no external forces or friction acting on the system. This is known as the conservation of energy.
How does energy conservation affect the amplitude and frequency of SHM in a spring?
According to the equation E = 1/2kA^2, the total energy is directly proportional to the square of the amplitude. This means that as the amplitude increases, the total energy also increases. However, the frequency (number of oscillations per unit time) remains constant regardless of the amplitude, as it is determined by the spring constant and mass of the system.
