SHM Oscillation problem involving potential energy
In summary, the conversation discusses using a graph to estimate the vibrational frequency of an HCl molecule, modeled as a spring between two atoms vibrating with simple harmonic motion. The equation used to calculate the frequency is derived and checked for any possible mistakes. Alternative methods are also explored to reach the same answer.
goraemon
67
A molecular bond can be modeled as a spring between two atoms that vibrate with simple harmonic motion. Figure P14.63 shows an SHM approximation for the potential energy of an HCl molecule. For E < 4 * 10^-19 J it is a good approximation to the more accurate HCl potential-energy curve that was shown in Figure 10.31. Because the chlorine atom is so much more massive than the hydrogen atom, it is reasonable to assume that the hydrogen atom (m = 1.67 * 10^-27 kg) vibrates back and forth while the chlorine atom remains at rest. Use the graph to estimate the vibrational frequency of the HCl molecule.
ƒ = (1/2PI) * sqrt(k/m)
Umax = (1/2)*k*A^2
I figured from the graph that the Amplitude (max. displacement) equals 0.17nm - 0.13 nm = 0.04 nm, which equals 4 x 10^-11 meters.It also appears from the graph that the max. potential energy is 4 x 10^-19 J. So:
Umax = (1/2)*k*A^2
4x10^-19 J = (1/2)*k*A^2
k = (4x10^-19 J) * 2 / A^2 = (4x10^-19 J) * 2 / (4x10^-11 m)^2 = 500 N/m
So, frequency = (1/2∏) * sqrt(k/m) = (1/2∏) * sqrt(500 N/m / 1.67x10^-27 kg) = 8.71x10^13 Hz
But the answer key says 7.9x10^13 Hz. I'm not sure where I went wrong. I would much appreciate any help.
  • asdf.pdf
OK - so the question is:
You have pulled the amplitude ##A## and max PE ##U_{max}## off the graph, then used the formula ##U_{max}=\frac{1}{2}kA^2## to compute ##k##.
You got the right order of magnitude - so it may just be a matter of the choice of value for something.
i.e. check your value for the amplitude more carefully - I get a different number to you using a set-square to line up the axis.
Note: it is best practice to do all the algebra before you put numbers in.
i.e. derive the equation that related the frequency with what you know.
Thanks for your response.
OK, I took another look at the graph and it seems like the amplitude might actually be closer to 0.045 nm = 4.5 x 10^-11 m...
So using the same equation as before, I get:
k = 2/A^2 * Umax = 2/(4.5x10^-11 m)^2 * 4x10^-19J = 395.06 N/m.
ƒ = 1/(2∏) * √(k/m)
= 1/(2∏) * √( (395.06 N/m) / (1.67x10^-27 kg) )
= 7.74x10^13 Hz
So my answer now is closer to the one in the answer key (7.9x10^13 Hz) than before, but still off by a bit. Aside from the possible mistake in measuring the amplitude from the graph, is there any other possible (more fundamental) mistake I might've made anywhere?
Just as an aside, I figured there's an alternative way to get the answer...
There's a formula that says Vmax = A*ω. We can begin by getting the value of Vmax via the following energy equation:
-> (1/2) * m * Vmax^2 = Umax
-> Vmax = √(2 * Umax / m) = √(2 * 4x10^-19J / 1.67x10^-27 kg) = 21887 m/s
So we solve for ω:
-> Vmax = A*ω
-> ω = Vmax / A = (21887 m/s) / (4.5x10^-11 m) = 4.8638 rad/s
-> Convert ω to ƒ -> (4.8638 rad/s) / (2∏) = 7.74x10^13 Hz
Again I get the same answer as before...have I made any mistakes in any of my computations, aside from possibly plugging in the wrong numbers? Thanks.
Any of you chosen values could be out.
Double check - why did you choose that particular value?
Think it through - which way to the values need to change to make a difference?
There is always more than one way to do things - best practice is still to do all the algebra first, then plug in the numbers. You are still refusing to do that for some reason. One of the sources of small mistakes is in implicit rounding off.
The "new" approach gets you to the same exact equation as before - there is no difference.
Finally - you have done just what I'd do.
It is always possible that the model answer is wrong ;)
Your approach and equations are correct, but there may have been a small error in your calculation. When solving for k, you should get k = 500 N/m, not 50 N/m. This would give a frequency of 7.9x10^13 Hz, which matches the answer key. Keep in mind that the difference between 50 N/m and 500 N/m is a factor of 10, which could easily lead to a difference of 1x10^13 Hz in the final answer.
Related to SHM Oscillation problem involving potential energy
1. What is SHM oscillation and how is it related to potential energy?
SHM (Simple Harmonic Motion) oscillation is a type of motion where an object moves back and forth in a regular pattern. It is related to potential energy because the object's oscillation is caused by the interplay between kinetic and potential energy. As the object moves, its potential energy is converted into kinetic energy, and then back to potential energy as it moves in the opposite direction.
2. How is the potential energy of an oscillating object calculated?
The potential energy of an oscillating object is calculated using the equation U = ½ kx², where U represents potential energy, k is the force constant of the oscillating system, and x is the displacement from the equilibrium position.
3. What is the relationship between the amplitude of an SHM oscillation and its potential energy?
The amplitude of an SHM oscillation is directly proportional to its potential energy. This means that as the amplitude increases, so does the potential energy of the object. This relationship can be seen in the potential energy equation, as the amplitude (x) is squared.
4. How does the mass of an oscillating object affect its potential energy?
The mass of an oscillating object does not directly affect its potential energy. However, it does affect the frequency of the oscillation, which in turn affects the amount of potential energy the object has at any given point in time. A larger mass will have a lower frequency and therefore a lower potential energy, while a smaller mass will have a higher frequency and potential energy.
5. How does friction impact the potential energy of an SHM oscillation?
Friction in an SHM oscillation system causes energy to be lost, reducing the amplitude and therefore the potential energy of the oscillation. This is because friction converts some of the object's kinetic energy into heat, which is dissipated into the surroundings. As a result, the object's oscillation will gradually decrease until it comes to a stop.
