Shooting a .45 caliber hand gun on the moon launches you a mile?
In summary, Shooting a .45 caliber hand gun on the moon "launches" you a mile? The energy given to the bullet isn't the same as the energy given to the shooter. The momentum is equal to that of the bullet. (and in opposite direction of course) Because of this your answer is much too high, and the distance is really insignificant.
007jbnd5
My co-worker and I were having a discussion about an activity that he did while at a teachers math conference. The activities was to rate the importance of objects. There were 15 objects and you are stranded on the moon 200 miles away from your base. One of the objects was a .45 caliber handgun with 2 rounds of ammunition. I put this as low importance (along with the matches lol) because there's nothing that's after you and it's not going to "launch" you any significant amount of distance. My co-worker had said that the guy running the activities put it higher because it can launch you a mile or two. I am a sophomore civil engineering student and I'm in a dynamics class right now so I did my own basic calculations to see how far you could go. What I found on the internet is a .45 caliber bullet fired from a handgun has anywhere from 500-1000 joules of energy. I am not sure if the expelled gasses would make a significant difference.
For my calculations I gave the bullet 1500 joules just to see what happens and to try to account for the expelled gasses.
What I got is
Newton's third law is every action has a equal and opposite reaction.
1500 joules in the bullet means 1500 joules transferred to the man firing it.
Let's say the man is 200 lb on Earth so about 90kg.
1500 joules / 90kg = 16.666666 m/s after shot
Let's say he fires it at 45 degrees towards the ground for max distance.
Vxi=16.66666cos(45)
Vyi=16.66666sin(45)
Kinematics equation for constant acceleration
Vf=Vi+at
Assume it's relatively flat and moons gravity is 1/6 of Earth's
Vyf=-16.66666sin(45)
-16.66666sin(45)=16.66666sin(45)+(-9.81/6)t
t=14.416
Distance in x direction is velocity times time
Distance=16.66666cos(45)*14.416
Distance is about 170 meters making the bullet fairly insignificant as your 200 miles from base and you have a lot of gear with you. If there's anything I'm not accounting for or if I messed up somewhere let me know.
You can't really answer the question without knowing the speed of the bullet.
suppose you have a 0.015 kg bullet going at 400 m/s, This is about as heavy and fast as a .45 pistol bullet can get. The energy is 1200 J.
The momentum of the bullet is 400 * 0.015 = 6 kg m/s
A 90 kg astronaut will have the same momentum with a speed of only 6/90 = 0.067 m/s
Flying time will be only 0.06 seconds, and the shooter will move only 4 mm.
Oops I just looked at the energy on the wiki page for .45 caliber handguns and for some reason (maybe it's because it's 1am) thought joules was momentum. Thanks for double checking my work.Helium walks into a bar and the bartender says, "we don't serve noble gases here." He doesn't react.
Fire a gun horizontally on Earth and what happens to the shooter? Would it be much different on the moon?
I would like to clarify that shooting a .45 caliber handgun on the moon would not "launch" a person a mile. While it is true that the expelled gasses from the gun may provide some additional force, it would not be enough to propel a person a significant distance. As the calculations show, the maximum distance the bullet could travel is about 170 meters, which is far less than a mile. Additionally, the weight of the person and other equipment they may have with them would also affect the distance they could potentially travel. Therefore, the importance of a handgun in a survival situation on the moon would not be due to its ability to launch a person a significant distance, but rather for its intended use as a tool for self-defense.
FAQ: Shooting a .45 caliber hand gun on the moon launches you a mile?
How is it possible to shoot a .45 caliber hand gun on the moon and be launched a mile?
The lack of atmosphere on the moon allows for the escape of gases at a much higher velocity when the gun is fired. This creates a strong enough force to launch a person a mile when shot from a .45 caliber hand gun.
Will the recoil of the gun be affected by the moon's gravity?
Yes, the recoil of the gun will be significantly reduced due to the moon's lower gravity compared to Earth. This is because there is less force pulling the gun and shooter back.
Can anyone shoot a .45 caliber hand gun on the moon and be launched a mile?
No, only trained astronauts with proper training and equipment would be able to safely shoot a gun on the moon. The extreme conditions and lack of atmosphere make it dangerous for untrained individuals to attempt this feat.
How far would a person be launched if they were shot from a different caliber gun on the moon?
The distance a person would be launched depends on the specific gun and its caliber. However, generally speaking, a person would be launched further from a higher caliber gun due to the increased force and velocity of the gases escaping.
Would the trajectory of the bullet be affected by the lower gravity on the moon?
Yes, the lower gravity on the moon would cause the bullet to travel in a more linear path compared to on Earth. This is because there is less force pulling the bullet down, allowing it to travel further before falling to the ground.
9K
