Shooting in a π/4 Angle: Is it Possible?
  • Thread starter fer Mnaj
  • Tags
    Angle
In summary: or maybe they meant "if the projectile land at it's original height", not "if the projectile land at it's original height".
fer Mnaj
34
Proof that in a parabolic motion with r0 = 0 and v_y0 = 0, the maximum horizontal range (in the x direction) is given by shooting with an angle of π / 4 inclination about the horizontal direction.
y(t)= y_0 +V_0y t-1/2 gt^2
x(t)= x_0+V_0x t
So the statement says that in r(0)=0, so it departs from the origin. And it also says that v_y0 = 0, thus meaning thar it´´´ s position in the y direction is Constant. Is shooting in a π / 4 angle still plausible? or there´ s no way that can happen? So far I´ ve thought since there´ s no acceleration affecting the movement, its position must be determine by x(t)= x_0+V_0x t which is x(t)= x_0+V_0cos (θ) t.
So what do you think?
fer Mnaj said:
Homework Statement:: Proof that in a parabolic motion with r0 = 0 and v_y0 = 0, the maximum horizontal range (in the x direction) is given by shooting with an angle of π / 4 inclination about the horizontal direction.
It does seem nonsensical.
Are you sure you have quoted the question exactly? Presumably it does not quite have "v_y0=0", but perhaps ##v_y(0) =0##, yes?
Is it a translation?
What if you stand at the top of a cliff, and throw the projectile horizontally out toward the sea? The initial vertical component of velocity would be zero, but it's position in the ##y## direction would definitely not b constant...
In any case, I have no idea how that would relate to proving that the optimum angle above the horizontal is ##\pi/4##.
I think you will need to upload the original problem statement :smile:
In the case of launching a projectile from the top of a cliff, the optimum launch angle to maximize horizontal range onto the flat plain below will not be ##\frac{\pi}{4}##.
In the case of a projectile launched with a vertical velocity component of zero and an angle of ##\frac{\pi}{4}## above the horizontal, the horizontal component will be zero as well. That projectile will drop like a stone. The maximum range will be equal to the minimum range which will be zero. This will be achieved by all launch angles, including ##\frac{\pi}{4}##.
Likes etotheipi
@jbriggs444 yes there is something that OP has omitted or transcribed incorrectly, because as stated the OP makes no sense :smile:
If, instead of ##v_{y0}=0##, the initial condition were ##y_0=0##, i.e. the projectile lands at its original height, the whole thing makes sense. However, for the title question to make more sense if it were "Is the maximum horizontal range still given by π / 4 in parabollic motion when the projectile launcher moves relative to the ground?" Something lost in translation?
I.e., it should say "if ##v_x(0)>0##"? That would make sense, but it's two typos.
I know that Einstein is rumoured to have said something along the lines of "if I had one hour to solve a problem, I'd spend 55 minutes thinking about the problem and 5 minutes thinking about solutions"... but I think we are taking this a little bit too literally :wink:
It seems like OP has done an Elvis Presley on us...
Related to Shooting in a π/4 Angle: Is it Possible?
1. Is it possible to shoot a projectile at a π/4 angle?
Yes, it is possible to shoot a projectile at a π/4 angle. This angle is also known as a 45-degree angle and is commonly used in physics and engineering calculations.
2. What is the significance of shooting at a π/4 angle?
Shooting at a π/4 angle allows for the maximum range and height of a projectile. This angle is also considered the most efficient for achieving the desired distance and trajectory.
3. How do you calculate the velocity needed for shooting at a π/4 angle?
The velocity needed for shooting at a π/4 angle can be calculated using the formula v = √(g * d / sin(2θ)), where v is the velocity, g is the acceleration due to gravity, d is the distance, and θ is the angle in radians.
4. Can shooting at a π/4 angle be used in real-life situations?
Yes, shooting at a π/4 angle is commonly used in real-life situations such as sports, military operations, and engineering projects. It is also used in everyday activities like throwing a ball or shooting a basketball.
5. Are there any limitations to shooting at a π/4 angle?
The main limitation of shooting at a π/4 angle is air resistance, which can affect the trajectory and distance of the projectile. Other factors such as wind and air temperature can also impact the accuracy of shooting at this angle.
