Short in Wires with 2 Different Resistances
In summary, a technician is trying to locate a short in a 6.00 km underground telephone cable by measuring the resistance between terminals AB and across terminals CD. The first measurement yields 10.00 Ohm and the second yields 95.00 Ohm. Using the equation for resistance (R = ρ*L/A), the technician can solve for the distance of the short from point C by setting up two equations for the resistances across AB and CD (R(AB) = (ρo/A)*2(L-x) and R(CD) = (ρo/A)*2x) and solving for x. This will determine the location of the short as a distance of x from point C.
skibum143
112
An underground telephone cable, consisting of a pair of wires, has suffered a short somewhere along its length (at point P in the Figure). The telephone cable is 6.00 km long, and in order to determine where the short is, a techician first measures the resistance between terminals AB; then he measures the resistance across the terminals CD. The first measurement yields 10.00 Ohm; the second 95.00 Ohm. Where is the short? Give your answer as a distance from point C.
I = V/R
Vtotal = I (R1 + R2)
ohm = V/A
Honestly, I have no idea where to even start with this question. I would know how to calculate the total voltage, but this problem doesn't give any voltage, and I don't know what length the ohm refers to? Also, it doesn't even look like AB are attached or CD are attached. Can someone help get me started? Thanks! I attached a picture of the problem.
The resistance of a wire is proportional to the length of the wire.
If x km is the distance of the short from C, then
95 ohm = k*2x.
Similarly write down the expression for the resistance across AB and solve for x.
What is k? The 8.98*10^9 constant?
and did you use 2x because there are two wires?
Νο. You know that
R = ρ*L/A. So k = ρ/Α, which is constant for a given wire.
Oh, I knew the resistance = ro*length / pi r^2, but i didn't know what Resistance is ro*length over area?
Sorry, I'm still completely confused. I'm not sure what I'm solving for using the second equation...
At P thew wires are short. If the CP = x. Length of the wire CPD = 2x. So the esiatance of this wire is
R(CD) = (ρo/A)*2x. Similarly
R(AB) = (ρo/A)*2(L-x).
Solve these two equations to find x.
FAQ: Short in Wires with 2 Different Resistances
What is a short in wires with 2 different resistances?
A short in wires with 2 different resistances refers to a situation where two wires with different resistance values are connected in a circuit without any other components in between. This can cause an unintended flow of current and can potentially damage the circuit.
How does a short in wires with 2 different resistances occur?
A short in wires can occur when there is a break or damage in the insulation of one of the wires, causing it to come into contact with the other wire. It can also occur when the wires are connected incorrectly or when there is a fault in the circuit design.
What are the potential consequences of a short in wires with 2 different resistances?
The consequences of a short in wires can vary depending on the circuit and the amount of current flowing through it. It can cause overheating and damage to the wires, components, and even the power source. In extreme cases, it can lead to electric shocks or fires.
How can a short in wires with 2 different resistances be prevented?
To prevent a short in wires, it is important to ensure that the wires are properly insulated and there are no breaks or damages. It is also crucial to follow proper wiring techniques and pay attention to the resistance values of the wires being used. Using fuses or circuit breakers can also help prevent potential damage in case of a short.
How can a short in wires with 2 different resistances be fixed?
If a short in wires occurs, the first step is to disconnect the power source and identify the location of the short. Once the short is located, the wires can be repaired or replaced. It is important to also check for any other damages or issues in the circuit before reconnecting the power source.
