Shortest distance between (18,0) and y=x^2
In summary, the shortest distance between $(18,0)$ and $y=x^2$ is approximately $16.5$ units, found by minimizing the distance equation $(18-x)^2 + (x^2)^2$ using calculus and finding the point $(2,4)$ on the graph of $y=x^2$.
karush
MHB
3,269
What is the shortest distance between $(18,0)$ and $y=x^2$
I presume this could be solved by slopes but couldn't get the formula set up
take any point say (x,x^2) on the graph
find the distance from (18 .0) that is $\sqrt{(18-x)^2 + (x^2)^2}$
minimize it or minimize $(18-x)^2 + x^4$
now u can proceed with help of calculus
Since $y=x^2$ then $y'=2x=m$
So
$${x}^{2 }=\frac{1}{-2x}\left(x-18\right)$$
From which we get $(2,4)$
$$\sqrt{\left(18-2\right)^2+\left(4-0\right)^2}=4\sqrt{17}\approx 16.5=d$$
FAQ: Shortest distance between (18,0) and y=x^2
What is the equation for the shortest distance between (18,0) and y=x^2?
The equation for the shortest distance between (18,0) and y=x^2 is d = (x-18)^2 + (y-x^2)^2.
How do you calculate the shortest distance between (18,0) and y=x^2?
To calculate the shortest distance between (18,0) and y=x^2, you can use the equation d = (x-18)^2 + (y-x^2)^2. Plug in the coordinates of (18,0) and solve for the value of d.
Is the shortest distance between (18,0) and y=x^2 a straight line?
No, the shortest distance between (18,0) and y=x^2 is not a straight line. It is a curve that represents the shortest distance between the two points.
Can the shortest distance between (18,0) and y=x^2 be negative?
No, the shortest distance between (18,0) and y=x^2 cannot be negative. Distance is always a positive value, representing the shortest length between two points.
How does changing the value of x affect the shortest distance between (18,0) and y=x^2?
Changing the value of x will affect the shortest distance between (18,0) and y=x^2 by altering the curvature of the curve. As x increases or decreases, the curve will shift and the shortest distance will change accordingly.
