Shortest distance scales that a string can resolve
In summary, the notes by Veronika Hubeny on The AdS/CFT correspondence discuss the surprises encountered when considering strings as extended objects in string theory. These include regularity in spacetimes that are singular in general relativity and controlled descriptions of topology-changing transitions. Additionally, the theory of mirror symmetry implies that spacetime geometry is not as fundamental as one might expect. This is exemplified by the fact that a spacetime with a compact direction of size ##R## looks the same to strings as one with a compact direction of size ##\ell_{s}^{2}/R##, meaning that strings cannot resolve distances shorter than the string scale ##\ell_{s}##. This is because even when going from ##R<
Afonso Campos
29
On page 5 of the notes (https://arxiv.org/abs/1501.00007) by Veronika Hubeny on The AdS/CFT correspondence, we find the following:
Nevertheless, already at this level we encounter several intriguing surprises. Since strings are extended objects, some spacetimes which are singular in general relativity (for instance those with a timelike singularity akin to a conical one) appear regular in string theory. Spacetime topology-changing transitions can likewise have a completely controlled, non-singular description. Moreover, the so-called 'T-duality' equates geometrically distinct spacetimes: because strings can have both momentum and winding modes around compact directions, a spacetime with a compact direction of size ##R## looks the same to strings as spacetime with the compact direction having size ##\ell_{s}^{2}/R##, which also implies that strings can’t resolve distances shorter than the string scale ##\ell_{s}##. Indeed this idea is far more general (known as mirror symmetry [11]), and exemplifies why spacetime geometry is not as fundamental as one might naively expect.
The penultimate sentence states that
A spacetime with a compact direction of size ##R## looks the same to strings as spacetime with the compact direction having size ##\ell_{s}^{2}/R##.
Why does this imply that strings can’t resolve distances shorter than the string scale ##\ell_{s}##?
Well, what happens if you go from ##R<\ell_{s}## to ##R>\ell_{s}##, bearing in mind that ##R\sim \ell_{s}^2 / R##?
The theory looks the same, but the string is probing length scales shorter than ##\ell_s##, right?
It's just that the long distance and short distance physics are the same.
FAQ: Shortest distance scales that a string can resolve
What is the concept of "shortest distance scales" in string theory?
In string theory, the concept of "shortest distance scales" refers to the smallest possible distance that can be measured between two points in space. This distance is theorized to be the Planck length, which is approximately 1.6 x 10^-35 meters.
How is the shortest distance scale related to the size of a string?
In string theory, strings are believed to be the fundamental building blocks of the universe. These strings are incredibly small, with a size of about 10^-33 meters. This means that the shortest distance scale that can be resolved by a string is approximately 10 times smaller than the size of a string itself.
Why is the shortest distance scale important in string theory?
The shortest distance scale is important in string theory because it is one of the fundamental principles that govern the behavior of strings. It helps to define the smallest possible unit of measurement and has implications for the structure of space and time at a microscopic level.
Can the shortest distance scale ever be measured or observed?
Currently, the shortest distance scale is beyond the capabilities of our technology to measure or observe. It is theorized to be at the Planck length, which is 10^20 times smaller than the size of a proton. This makes it practically impossible to detect at our current level of understanding and technology.
How does the concept of shortest distance scales in string theory impact our understanding of the universe?
The concept of shortest distance scales in string theory has led to a deeper understanding of the fundamental structure of the universe. It has also helped to reconcile the theories of general relativity and quantum mechanics, providing a potential framework for a theory of everything.
