Should This System Settle? - Discrepancy in MathCad Solving Methods
In summary, the conversation discussed the use of various methods to solve a system with two blocks and a spring, with an initial velocity of 10m/s for one block. The methods used were Euler, Euler-Cramer, Runge-Kutta (2nd Order) in Excel, and Adams/BDF, Stiff, Adaptive, and Radau in Mathcad. All methods initially showed agreement, but there was disagreement in the long term solution. The question was whether the system will ever settle, and if a stiff solver should be used. It was suggested that without damping, the system will not settle, and the use of a stiff solver may introduce artificial damping. It was also recommended to try splitting the mass into two equal masses and
aragorn77777
I've been playing around with the following system for the last little while:
(attached image: 2 Blocks + Spring.jpg)
- Block B starts with an initial velocity of 10m/s
I solved the differential equations with a variety of methods in Excel and Mathcad:
Excel:
Euler
Euler-Cramer
Mathcad:
Adams/BDF
Stiff
Adaptive
Radau
(various options with ODESOLVE)
- All of the methods are in agreement during the first part of the response.
- But there seems to be disagreement in the long term. According to almost all of the solvers, the oscillations continue indefinitely. The stiff solver, however, shows the oscillations eventually settling (relative motion between the two blocks goes to zero and the entire system continues to accelerate to infinity in the direction of the greater force).
1. So the big question is: Will this system ever settle?!
2. A related scenario. If you have:
-mass on a spring with one end fixed
-no damping
-constant external force
Does this system eventually settle? I'd be happy just with a conceptual answer (i.e. - this type of system will never settle down without damping - or - you shouldn't use the Stiff solver if the system is not even close to stiff --- something along those lines) --- I don't expect anyone to sort through the Mathcad solution and come up with numerical answers.
I've attached two Mathcad files:
1. The short term behaviour
2. The long term behaviour (solver set to Stiff)
Any help would be greatly appreciated!
  • Spring and 2 Blocks - Short Term.xmcd
  • Spring and 2 Blocks - Long Term.xmcd
If there is no damping, the mathematical solution to the ODEs will never "settle" (unless the forces FA and FB are time dependent, and carefully chosen to make it "settle".
I don't know what method the "stiff" solver in Mathcad uses, but it is fairly "normal" for a stiff solver's solution method to introduce artificial (or "algorithmic") damping. Often the large (high frequency) eigenvalues that make the system "stiff" are just an artefact of the way the math model is constructed, and don't correspond to anything that is physically interesting. Damping out the uninteresting high frequency transient response means the solver can take bigger time steps (possibly several orders of magnitude bigger) and still give a solution that is accurate enough for practical purposes.
But since your model only has 2 DOF, and the system is not stiff, the "stiff" solver may be damping out part of the system response that IS interesting.
If you want to play with this, split your mass A into two equal masses, and join them with a very stiff spring, say 106 times as stiff as the other spring in your model. Most of the solution methods, except for the "stiff" solver, will probably run 106 times slower.
Thanks a bunch! Much appreciated!
Related to Should This System Settle? - Discrepancy in MathCad Solving Methods
1. How do you determine if a system should settle?
The settling of a system can be determined by analyzing the results of the math solving methods used. If the methods produce consistent and accurate results, then the system can be considered settled. However, if there are discrepancies in the results, further investigation may be needed to determine if the system has truly settled.
2. What are some common discrepancies in MathCad solving methods?
Some common discrepancies in MathCad solving methods include inconsistent or inaccurate results, convergence errors, and difficulty in solving equations with multiple variables or complex functions.
3. How can discrepancies in MathCad solving methods be resolved?
Discrepancies in MathCad solving methods can be resolved by checking for errors in the input data and equations, adjusting the initial conditions or solver parameters, and using alternative solving methods or software.
4. What are some tips for ensuring accurate results in MathCad solving methods?
To ensure accurate results in MathCad solving methods, it is important to carefully check for errors in the input data and equations, use appropriate initial conditions and solver parameters, and understand the limitations of the solving methods being used.
5. Can discrepancies in MathCad solving methods affect the overall accuracy of a scientific study?
Yes, discrepancies in MathCad solving methods can significantly affect the overall accuracy of a scientific study. It is important to thoroughly test and validate the solving methods being used to ensure that the results are reliable and can be used to draw accurate conclusions.
  • Differential Equations
