Show 1 - x/3 < sinx/x < 1.1 - x/4
  • MHB
  • Thread starter anemone
In summary, we can see that by multiplying the given inequality by $x$, we can prove that 1-\frac{x}{3}<\frac{\sin x}{x}<1.1-\frac{x}{4} is true for $0<x\le \pi$. This is done by considering the parts to prove separately and using the concepts of differentiation and maximum and minimum values.
anemone
MHB
POTW Director
3,883
115
Show that \(\displaystyle 1-\frac{x}{3}<\frac{\sin x}{x}<1.1-\frac{x}{4}\) for $0<x\le \pi$.
Mathematics news on Phys.org
Re: Show 1-x/3<sinx/x<1.1-x/4
Hi MHB,
The solution presented below is proposed by Georges Ghosn:
Since the inequality defined for $0<x\le \pi$, what we could do with the given inequality(\(\displaystyle 1-\frac{x}{3}<\frac{\sin x}{x}<1.1-\frac{x}{4}\)) is to multiply it through by $x$ and hence what we need to prove now is this: \(\displaystyle x-\frac{x^2}{3}<\sin x<1.1x-\frac{x^2}{4}\).
First, we consider the part to prove $x-\frac{x^2}{3}<\sin x$.Next, we need to prove \(\displaystyle \sin x< 1.1x-\frac{x^2}{4}\).
Let
\(\displaystyle f(x)=\sin x-x+\frac{x^2}{3}\)
Differentiating it once we get:
\(\displaystyle f'(x)=\cos x-1+\frac{2x}{3}\)
and differentiating it again we have:
\(\displaystyle f''(x)=-\sin x+\frac{2}{3}\)
Let
\(\displaystyle g(x)=\sin x-1.1x+\frac{x^2}{4}\)
\(\displaystyle g'(x)=\cos x-1.1+\frac{x}{2}\)
\(\displaystyle g''(x)=-\sin x+\frac{1}{2}\)
Observe that \(\displaystyle f"(x)>0\) for \(\displaystyle 0<x< \pi\) except when \(\displaystyle a<x<b\) where \(\displaystyle \sin a= \sin b=\frac{2}{3}\) and this implies also \(\displaystyle a<\frac{\pi}{2}<b\).Thus, $f'(x)$ increases from $0$ to a maximum at $x=a$, then decreases to a minimum at $x=b$, and then increases again from $b$ to $\pi$.
The minimum value is \(\displaystyle f'(b)=\cos b-1+\frac{2b}{3}>\cos (\frac{\pi}{2})-1+\frac{2(\frac{\pi}{2})}{3}>\frac{\pi}{3}-1>0\).
From this we know that $f'(x)\ge 0$ for $0 \le x \le \pi$ and consequently, $f(x)$ increases from $0$ to \(\displaystyle \pi(\frac{\pi}{3}-1)\) and this gives \(\displaystyle \sin x\ge x-\frac{x^2}{3}\).
By using the similar concept that applied in the previous
case, we have
$g"(x) \ge 0$ except for \(\displaystyle \frac{\pi}{6}<x<\frac{5\pi}{6}\) where $g"(x) < 0$. So $g'(x)$ increases from a value of $-1.1$ to a maximum of \(\displaystyle \cos \frac{\pi}{6}-1.1+\frac{\frac{\pi}{6}}{2}>0\). It must be zero at a point, \(\displaystyle x=p (0\le p \le \frac{\pi}{6}\).
Similarly, $g'(q)=0$ for \(\displaystyle \frac{\pi}{6}<x<\frac{5\pi}{6}\). Note that \(\displaystyle g'(\frac{\pi}{4})=\frac{\sqrt{2}}{2}-1.1+\frac{3\pi}{8}<0\), so \(\displaystyle \frac{\pi}{4}\le q \le \frac{3\pi}{4}\). Then from $0$, $g(x)$ decreases to a minimum at $x=p$, then increases to a maximum value at $x=q$. $g'(q)=0=\cos q-1.1+\frac{q}{2}$ or $q=2(1.1-\cos q)$.
Thus, $g(q)=\sin q-1.1q+\frac{q^2}{4}=\sin q+\cos^2 q-(1.1)^2=(0.03-\sin q)(\sin q-0.7)<0$ since $\sin q \ge \frac{\sqrt{2}}{2}$.
From this $g(x)=\sin x-1.1+\frac{x^2}{4} \le 0$ for $0\le x\le \pi$.
And therefore we prove that \(\displaystyle 1-\frac{x}{3}<\frac{\sin x}{x}<1.1-\frac{x}{4}\) is true for $0<x\le \pi$.
FAQ: Show 1 - x/3 < sinx/x < 1.1 - x/4
1. What does the equation "x/3 < sinx/x < 1.1 - x/4" represent?
The equation represents a mathematical inequality, where the value of the expression "sinx/x" lies between the values of "x/3" and "1.1-x/4".
2. What is the significance of the inequality in this equation?
The inequality shows the relationship between the values of "x" and the value of "sinx/x". It also provides a range of values for which the inequality holds true.
3. How can this equation be solved?
The equation can be solved by manipulating the inequality to isolate the value of "x". This can be done by multiplying or dividing both sides by a constant, or by using algebraic techniques such as factoring or substitution.
4. What is the purpose of using "sinx/x" in the equation instead of just "sinx"?
Using "sinx/x" instead of just "sinx" allows for a wider range of values to be considered in the inequality. It also helps to simplify the equation and make it easier to solve.
5. How can this equation be applied in real-life situations?
This type of inequality can be used in a variety of real-life situations, such as calculating the maximum or minimum values of a function or determining the range of values for a given variable. It can also be used in physics and engineering problems involving trigonometric functions.
