Show congruence with Lucas sequence
  • MHB
  • Thread starter evinda
  • Tags
    Sequence
In summary, the conversation is about proving the congruence $2^n L_n \equiv 2 \pmod{10}$ for the Lucas sequence $L_n$. The conversation discusses different approaches and definitions of the Lucas sequence and how to use induction to prove the congruence. One approach involves starting from the definition of $L_n$ and using binomial expansions, while another approach involves using the property $L_n = L_{n-1} + L_{n-2}$ and a proper recursive definition of $L_n$.
evinda
MHB
3,836
Hello! (Wave)
I want to show that for each $n \geq 1$ it holds that $2^n L_n \equiv 2 \pmod{10}$.
$L_n$ is the Lucas sequence.
According to my notes,
$$L_n=\left( \frac{1+\sqrt{5}}{2}\right)^n+\left( \frac{1-\sqrt{5}}{2}\right)^n$$
and
$$L_n=F_{n-1}+F_{n+1},$$
where $F_n$ is the $n$-th Fibonacci number.
Could you give me a hint how we get the desired congruence? (Thinking)
Mathematics news on Phys.org
evinda said:
Hello! (Wave)
and
Hey evinda!
Don't we have $L_n = L_{n-1} + L_{n-2}$?
Perhaps we can apply induction? (Wondering)
Klaas van Aarsen said:
Hey evinda!
Since $L_n=F_{n-1}+F_{n+1}$, does it hold that $L_n$ is only defined for $n \geq 2$ ? :confused:
Also, we have that $L_2=F_1+F_3=1+F_1+F_2=3$.
For $n=2$: $2^n L_n=2^2 L_2= 4 \cdot 3=12 \equiv 2 \pmod{10}$.
Then we suppose that $2^k L_k \equiv 2 \pmod{10}$.
Then $2^{k+1} L_{k+1}=2 \cdot 2^k (L_k+L_{k+2})$.
Is it right so far? If so, how can we continue? (Thinking)
Wiki says here:
The Lucas numbers may thus be defined as follows:
L_n :=
\begin{cases}
2 & \text{if } n = 0; \\
1 & \text{if } n = 1; \\
L_{n-1}+L_{n-2} & \text{if } n > 1. \\
\end{cases}
Isn't that consistent with your definition?
Usually $F_0=0, F_1=1, F_2=1, F_3=2$.
It follows that $L_1=1, L_2=3$, and we can choose to define $L_0=2$. (Thinking)
Shouldn't that be: $2^{k+1} L_{k+1}=2 \cdot 2^k (L_{k}+L_{k-1})$ ? (Wondering)
Note that:
$$L_{n-1}+L_{n-2}=(F_{n-2}+F_n)+(F_{n-3}+F_{n-1})=(F_{n-3}+F_{n-2})+(F_{n-1}+F_{n})=F_{n-1}+F_{n+1}=L_n$$
And we basically need to have a proper recursive definition of $L_n$ to apply induction. (Thinking)
evinda said:
Hello! (Wave)
and
Another approach would be to start from the definition $L_n=\left( \frac{1+\sqrt{5}}{2}\right)^n+\left( \frac{1-\sqrt{5}}{2}\right)^n$. So $2^nL_n=(1+\sqrt{5})^n+(1-\sqrt{5})^n$. Now form the binomial expansions: \[\textstyle \bigl(1 + {n\choose1}\sqrt5 + {n\choose2}5 + \ldots\bigl)\ +\ \bigl(1 - {n\choose1}\sqrt5 + {n\choose2}5 + \ldots\bigl)\] When you add the two series, the first term is $2$, the odd-numbered terms (involving $\sqrt5$) all cancel, and the remaining terms are all multiples of $2$ and of $5$.
Ah, I see... Thank you... (Smile)
- - - Updated - - -
Note that:
We cannot use this property because it contains both $L_{n-1}$ and $L_{n-2}$... Or am I wrong?
It's the proof that $L_n=L_{n-1} + L_{n-2}$.
This proof uses only the definition for the Lucas numbers in post #1, doesn't it? (Wondering)
FAQ: Show congruence with Lucas sequence
What is a Lucas sequence?
A Lucas sequence is a sequence of numbers where each term is the sum of the two preceding terms, similar to the Fibonacci sequence. It is named after the mathematician Édouard Lucas.
How is the Lucas sequence related to other mathematical concepts?
The Lucas sequence is closely related to the Fibonacci sequence, as both are examples of linear recurrence relations. It can also be used in the study of number theory, particularly in relation to prime numbers.
What is the formula for finding the nth term in a Lucas sequence?
The formula for finding the nth term in a Lucas sequence is: Ln = φ^n + (1-φ)^n, where φ is the golden ratio (approximately 1.618) and n is the term number.
How can the Lucas sequence be used in real-world applications?
The Lucas sequence has been applied in various fields such as finance, computer science, and biology. For example, it can be used to model population growth or in the development of efficient algorithms.
Is the Lucas sequence a finite or infinite sequence?
The Lucas sequence is an infinite sequence, as it continues infinitely with no repeating pattern. However, in practical applications, a finite number of terms may be used for calculation purposes.
