MHB Show $\displaystyle \lim_{x \to \infty} \frac{50x^{10}+100}{x^{11}+x^6+1}=0$
To show that the limit of the expression as x approaches infinity equals zero, focus on the highest degree terms in the numerator and denominator. The limit simplifies to $\lim_{x \to +\infty} \frac{50x^{10}}{x^{11}}$, which further reduces to $\lim_{x \to +\infty} \frac{50}{x}$. As x increases, this limit approaches zero. The discussion emphasizes the importance of considering only the leading terms in polynomial fractions for limits at infinity. The conclusion confirms that the limit is indeed zero.
Guest2
How do you show that $\displaystyle \lim_{x \to \infty} \frac{50x^{10}+100}{x^{11}+x^6+1}=0$
What I tried:
$\displaystyle \lim_{x \to \infty} \frac{50x^{10}+100}{x^{11}+x^6+1} =\lim_{x \to \infty} \frac{50+100/x^{11}}{1+1/x^{5}+1/x^{11}} = \frac{50+0}{1+0+0} = 50.$
But this is wrong. (Angry)
If you have a fraction of polynomials and you want to find the limit as $x \to +\infty$ you look only at the terms of largest degree.
So your limit is equal to $\lim_{x \to +\infty} \frac{50 x^{10}}{x^{11}}=\lim_{x \to +\infty} \frac{50}{x}=0$
Thanks. When is it that we divide the highest power then?
You could also divide by the highest power in this case, if you would want to. The result will be the same...
I get it now - my algebra was wrong in the original post.
$\displaystyle \lim_{x \to \infty} \frac{50x^{10}+100}{x^{11}+x^6+1} =\lim_{x \to \infty} \frac{50/x+100/x^{11}}{1+1/x^{5}+1/x^{11}} = \frac{0+0}{1+0+0} = 0$
Thanks, again.
  • · Replies 16 ·
