Show inclusion map extends to an isometry
psie
259
31
Show that when ##Y## is a completion of ##X##, then the inclusion map ##X\to Y## extends to an isometry of ##\tilde X## onto ##Y##.
We say that a complete metric space ##Y## is the completion of ##X## if ##X## is a dense subspace of ##Y##. Above ##\tilde X## is the set of equivalence classes of the set of Cauchy sequences in ##X##, under the relation ##(s_n)\sim(t_n)## defined by ##d(s_n,t_n)\to0## as ##n\to\infty##. The metric on ##\tilde X## is ##\rho(\tilde{s},\tilde{t})=\lim_{n\to\infty} d(s_n,t_n)##, where ##\tilde s,\tilde t## are equivalence classes in ##\tilde X##.
I'm working an exercise on the completion of metric spaces. This exercise is from Gamelin and Greene's book and part of an exercise with several parts to it. I have already shown that ##\sim## is an equivalence relation, ##\rho## is a metric on ##\tilde X##, ##(\tilde X,\rho)## is complete and that ##X## gets mapped onto a dense subset of ##\tilde X## under the map that ##x\mapsto \tilde x##, where ##\tilde x## is the equivalence class of the constant sequence ##(x,x,\ldots)##.
However, I am really stuck at this last part of the exercise. What confuses me mightily is that the metric on ##Y## seems unspecified. As far as I understand, we want to find a map ##f:\tilde X\to Y## such that ##f## is an isometry and that ##f\circ e=i##, where ##e:X\to\tilde X## is the map ##x\mapsto \tilde x## and ##i:X\to Y## the inclusion map. How can we check ##f## is an isometry without knowing the metric on ##Y##?
We do know some things about the metric on ##Y##.
By dint of ##Y## being a completion of ##X##, we know that ##d_Y(i(x1),i(x2))=d_X(x1,x2)##.
So we only need to consider ##d_Y(y,i(x1))## and ##d_Y(y1,y2)## where ##y, y1,y2\in Y - i(X)##.
To do that, we need to define ##f##. For ##w\in e(X)## we can do that using the equation you wrote, since the functions ##e## and ##i## are known.
We then need to define ##f(w)## for ##w\in \tilde X - e(X)##. Since each such ##w## is a collection of non-convergent Cauchy sequences in ##X##, we can map it to the limit in ##Y## of the image under ##i## of such sequences.
We use such mappings to complete our function ##f##.
Having completed our function ##f##, the fact that it preserves distances will follow naturally from the way we have constructed it.
For ##f## to be an isometry requires it to be a bijection, so we also need to prove there are no elements of ##Y## outside the image of the the completed function ##f##, and that no two points in ##X## map to the same point in ##Y##, but that should be pretty easy.
Likes psie
Thanks. I do not follow part of your reasoning.
1. Why is this known? I have shown that the map ##x\mapsto\tilde x## is an isometry, but you seem to be stating that the inclusion map is also an isometry, which I don't see how to show.
2. I don't understand how this follows from your previous point. Why do we only need to consider ##d_Y(y,i(x1))## and ##d_Y(y1,y2)## where ##y,y1,y2\in Y-i(X)##?
3. I don't see from the way we've constructed ##f## that it is an isometry. Here I feel like the metric on ##Y## matters, since ##f## is an isometry if ##d_Y(f(\tilde x_1),f(\tilde x_2))=\rho(\tilde x_1,\tilde x_2)##.
4. I guess we can simply choose the codomain of ##f## to be the image of ##f##. How would one show injectivity?
My main concern was in showing that ##f## is an isometry. I think I've figured it out.
To see that ##f## is an isometry, we simply have to verify that $$d_Y(f(\tilde s),f(\tilde t))=\rho(\tilde s,\tilde t).$$The right-hand side is by definition simply ##\lim_{k\to\infty}d(s_k,t_k)## and since the left-hand side is ##d_Y(\lim_{k\to\infty}s_k,\lim_{k\to\infty}t_k)=\lim_{k\to\infty}d_Y(s_k,t_k)=\lim_{k\to\infty}d(s_k,t_k)##, so indeed, we have that ##f## is an isometry by continuity of the metric.
Maybe you can test, verify using the Reals as the Metric Completion of the Rationals. Y-X will consist of the Irrationals; introduced as putative limits of sequences of Rationals that don't converge within the Rationals themselves.
##Y## is any completion of ##(X,d)## and that means by definition there is a metric ##\rho## on ##Y## such that there exists an isometry ##j:X\to Y## that is almost surjective (i.e ##j(X)## is dense everywhere in ##Y##).
The point of the exercise is to show that any two completions of ##(X,d)## are isometrically isomorphic. And to that end it suffices to show that this abstract version of completion is isomorphic to the quotient space ##\overline{X}##, which equipped with the metric ##d^*([(x_n)],[(y_n)]) := \lim d(x_n,y_n) ##.
  1. Define ##f:\overline{X}\to Y, [(x_n)] \mapsto \lim j(x_n) \in Y## and show that ##f## is well defined.
  2. Now take two classes ##[(x_n)], [(y_n)]\in\overline{X}## and we can compute:
    [tex]
    \begin{align*}
    \rho (f[(x_n)], f[(y_n)]) &= \rho (\lim j(x_n), \lim j(y_n)) = \rho (\lim (j(x_n),j(y_n))) = \lim \rho (j(x_n),j(y_n)) \\
    &= \lim d(x_n,y_n) = d^* ([(x_n)], [(y_n)]).
    \end{align*}
    [/tex]
  3. Finally, verify that ##f\circ e = j##, where ##e:X\to\overline{X}## is the inclusion. Take ##x\in X##, then
    [tex]fe(x) = f[(x)] = \lim j(x) = j(x).
    [/tex]
All the heavy lifting and epsilonics are contained within the process of defining ##\overline{X}##.
Likes psie
