I Show Maxwell's Eqns. on a Cauchy Surface (Wald Ch. 10 Pr.2)
ergospherical
Education Advisor
Insights Author
This problem is Wald Ch. 10 Pr. 2.; it asks us to show that ##D_a E^a = 4\pi \rho## and ##D_a B^a = 0## on a spacelike Cauchy surface ##\Sigma## (with normal vector ##n^a##) of a globally hyperbolic spacetime ##(M, g_{ab})##. Using the expression ##E_a = F_{ab} n^b## for the electric field gives ##D_a E^a = {h^a}_b {h_a}^c \nabla_c E^b##. I replace ##{h^a}_b {h_a}^c = (\delta^a_b + n^a n_b)(\delta_a^c + n_a n^c) = \delta_b^c+ n_b n^c = {h_b}^c##, thereby obtaining\begin{align*}
D_a E^a &= {h_b}^c \nabla_c (F^{bd} n_d) = \nabla_b (F^{bd} n_d) + n_b n^c \nabla_c (F^{bd} n_d) \\
&= n_d \nabla_b F^{bd}+ F^{bd} \nabla_b n_d + n^c n_b n_d \nabla_c F^{bd} + n_b n^c F^{bd} \nabla_c n_d
\end{align*}The third term vanishes because ##n_b n_d \nabla_c F^{bd} = n_{(b} n_{d)} \nabla_c F^{[bd]} = 0##. Also, since ##n^a## is orthogonal to ##\Sigma##, the condition ##n_{[b} \nabla_c n_{d]}## holds i.e. ##n_b \nabla_c n_d## is totally antisymmetric, and the sum of the second and fourth terms is ##F^{bd} \nabla_b n_d + n_b n^c F^{bd} \nabla_c n_d = F^{bd} \nabla_b n_d - n_c n^c F^{bd} \nabla_b n_d = 2F^{bd} \nabla_b n_d##. Using Maxwell's equation ##\nabla^a F_{ab} = -4\pi j_b## on the first term gives\begin{align*}
D_a E^a &= -4\pi n_d j^d + 2F^{bd} \nabla_b n_d \\
&= 4\pi \rho + 2F^{bd} \nabla_b n_d
\end{align*}Does ##2F^{bd} \nabla_b n_d = 0##, i.e. is ##\nabla_b n_d## symmetric? I can't see why this should be so. (I thought about ##0 = \nabla_b(-1) = \nabla_b(n_a n^a) = n^a \nabla_b n_a##, but this doesn't seem to help).
This is up to a sign the second fundamental form, which is symmetric. With mathematical notations you can do the following. Let ##n## be the normal, and ##X,Y## tangent to the surface. Then differentiating ##g(n,Y)=0## you get ##g(\nabla _X n,Y)+g(n,\nabla _XY)=0##. So your expression is the negative of ##g(n,\nabla _XY)##, which is symmetric because ##g(n,\nabla _XY)=g(n,\nabla _YX)+g(n,[X,Y])##. The last term is zero because the comutator is also tangent to the surface.
  • Love
Likes George Jones, vanhees71, ergospherical and 1 other person
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
