Show ##\{nx^{n}(1-x)\}_{n = 0}^{\infty}## converges uni
  • Thread starter Euklidian-Space
  • Tags
    Uni
Actually, your sequence ## f_n(x)=nx^n(1-x) ## does not converge uniformly on ## [0,1] ##.It converges pointwise to zero on that interval. However, if you set ## x_n=\frac{n}{n+1} ## which is the value at which ## f_n ## reaches its maximum over ## [0,1] ## , you find that ##f_n(x_n)=(\frac{n}{n+1})^{n+1}=(1-\frac{1}{n+1})^{n+1} \ _{\overrightarrow{n\rightarrow\infty}}\frac{1}{e}>0 ## and this proves that the
Euklidian-Space
38
show ##\{nx^{n}(1-x)\}## converges uni on [0,1]
Note, that ##\sum nx^n(1-x)## converges uni on [0,1] by Abels' Theorem. Therefore the series follows the cauchy criterion,
##\forall \epsilon > 0##, ##\exists N > 0 ## such that if n,n > N then
$$\left|(m+1)x^{m+1}(1 - x) + ... + nx^{n}(1- x)\right| < \epsilon\,\,\, \forall x \in [0,1]$$,
Now since ##nx^n(1 - x) \geq 0## for all n we can say
$$\left|nx^{n}(1 - x) - mx^{m}(1 - x)\right| < \epsilon\,\,\, \forall x \in [0,1].$$
Which implies that ##\{nx^n(1 - x)\}## is uniformly cauchy ##\forall x \in [0,1]## and therefore uniformly convergent for ##x \in [0,1]##
Dont know if this is right
Euklidian-Space said:
Note, that ## \sum nx^n(1−x) ## converges uni on [0,1] by Abels' Theorem
Care to elaborate ?
Note that once you've said that, you're done - if the series converges uniformly so does the sequence of course, there is no need for a Cauchy argument. But your first step is mysterious (and unnecessary).
wabbit said:
Care to elaborate ?
Well my version of Abel's theorem states
Let ##g(x) = \sum a_{n}x^{n}## that converges at some point R > 0. Then the series converges uniformly on [0,R]. I used the cauchy argument since we never proved series uniformly convergent implies the sequence is uniformly convergent.
That is:
1) Incorrect, if ##g(x)## converges at some point ##R>0##, then you are only guaranteed convergence on ##[0,r]## for ##r<R##.
2) Not what Abel's theorem says.
See http://jlms.oxfordjournals.org/content/s1-39/1/81.extract
Likes WWGD
micromass said:
That is:
i am quite literally picking this up verbatim from my text
it is attached to this post
Which book is this? The flaw in the proof seems to be assuming that ##\left( \frac{x}{R} \right)^n## is monotone decreasing, which is not the case for ##x=R##.
understanding analysis, Abbot
OK, never mind. The theorem and proof is correct. Your proof is correct too then.
But, your proof is unnecessarily complicated by the way. It is much easier to find the maximum of the function on each interval, and to prove those maxima converge to ##0##. There is no real reason to transform this into a power series.
Yeah we haven't been given that theorem, this was me trying to tackle this thing with the tools available
It converges pointwise to zero on that interval. However, if you set ## x_n=\frac{n}{n+1} ## which is the value at which ## f_n ## reaches its maximum over ## [0,1] ## , you find that ##f_n(x_n)=(\frac{n}{n+1})^{n+1}=(1-\frac{1}{n+1})^{n+1} \ _{\overrightarrow{n\rightarrow\infty}}\frac{1}{e}>0 ## and this proves that the convergence is not uniform.
Edit : the reason your proof is incorrect, and the theorem you quote is not applicable here, is that ## \sum nx^n(1-x) ## is not a power series. You can of course write it as ## (1-x)\sum nx^n ## but then you will note that the power series ## \sum n x^n ## does not converge for ## x=1 ## so you cannot use that theorem.
ok, so if it doesn't converge uni then isn't it weird that
$$\lim_{n\rightarrow \infty}\int_{0}^{1} f_{n} \rightarrow 0?$$
Isn't uniform convergence a necessary condition for that?
No, uniform convergence is a sufficient condition for the convergence of the integral, but by no means a necessary one - as this example shows.
This just implies that the series ##\sum_{n=0}^N x^n## converges uniformly on ##[0, 1 - \epsilon]## for any small ##\epsilon > 0##. Thus, ##\sum_{n=0}^N (1-x)x^n## converges to 1 uniformly on ##[0, 1-\epsilon]##. This does not say what happens right at ##x = 1##, because then you have a series of terms that all = 0 (and, somehow, you want that series to converge to 1?)
hmmm, never said anything about converging to 1...I said that the theorem implies that it converges uni on [0,1]. It does say what happens at x = 1. The original series equals zero at x = 1. Therefore it converges at some point x = R = 1 > 0. Therefore it converges for [0,R] = [0,1]
hmmm, never said anything about converging to 1...I said that the theorem implies that it converges uni on [0,1]. It does say what happens at x = 1. The original series equals zero at x = 1. Therefore it converges at some point R = 1. Therefore it converges for [0,R] = [0,1]
As I mentionned in my previous post, the original series you wrote is not a power series so you cannot apply Abel's theorem to it.
my only issue wabbit is that in my class we did not get the theorem you applied to show it is not uni conv. i do not know how to approach it without that theorem
You did not mention convergence to 1, but I did.
You have a series that converges uniformly to 1 for ##0 \leq x \leq 1 - \epsilon## (for any small ##\epsilon > 0##), but which converges to 0 when ##x = 1## exactly. You may call that uniform convergence on [0,1], but I---for one---would not.
I do not see where you are getting that the series converges to 1. that's not even the point wise limit. Maybe i am misunderstanding you
I did not use a theorem in particular, could you be more specific as to what you find unclear in the proof I gave ?
For ##|x| < 1## we have
[tex]\sum_{n=0}^N x^n = \frac{1-x^{N+1}}{1-x} \to \frac{1}{1-x} [/tex]
as ##N \to \infty##. Thus, ##\sum_n (1-x) x^n \to 1##.
you used the lim sup right? Finding the maximum of ##f_{n}## and showing that the limit of ##f_{n}(x_{max})## does not go to zero?
I did not exactly use a limit-sup (and certainly no theorem about lim sup) but yes for the rest. It would be easier if you quoted the step you are having difficulty with so I could elaborate on it.
wabbit said:
I did not exactly use a limit-sup but yes for the rest. It would be easier if you quoted the step you are having difficulty with so I could elaborate on it.
well, what you used to show it is not uni conv we have not been taught, therefore i must find another way to show that the sequence is not uni conv
No. I used only the definition of uniform convergence, and you can follow that proof. Try it.
We are using different definitions then. here is mine...
OK. So you understand why ## f_n(x_n)\rightarrow \frac{1}{e}>0 ## and the only thing you miss is why this contradicts the definition of uniform convergence ## f_n\rightarrow_u 0 ## , is that right ?
If so, try ## \epsilon=\frac{1}{2e} ## and check your definition. Do you see why there is a contradiction ?
Right, so sticking with YOUR definition of uniform convergence, we have that the sequence of functions
[tex] S_N(x) = \sum_{n=0}^N (1-x) x^n [/tex]
converges uniformly (to 1) on the interval ##[0,1-\epsilon]##. (You need to do a bit of work and use some previous theorems to establish uniformity of convergence, but it is not very hard.) However, ##S_N(1) = 0 ## for all ##N##, so by your very own definition, the convergence of ##S_N(x)## cannot be uniform (because the limit function ##\lim_N S_N(x)## is not continuous on ##[0,1]##.
OK I'll let Ray explain, there's no point in doing it in two voices other than creating confusion, this thread is already getting unreadable. I'll move aside, you can ping me if you need.
@Euklidian-Space as you asked for more detail :
To expand this last step, let's assume uniform convergence, and take ## \epsilon=\frac{1}{2e} ## .
From the convergence of ## f_n(x_n) \rightarrow \frac{1}{e}## we know that
(1) ## \exists n_0,\forall n\geq n_0, f_n(x_n)>\frac{1}{2e}##
But uniform convergence ## f_n\rightarrow_u 0 ## tells us that
(2) ## \exists N, \forall n\geq N, \forall x \in [0,1], f(x)<\frac{1}{2e} ##
Now take any ## n\geq\max(n_0,N) ## and set ## x=x_n ## .
By (1) we have ## f_n(x)>\frac{1}{2e} ## , but (2) yields ## f_n(x)<\frac{1}{2e} ## so we have a contradiction.
  • #31
Wabbit,
i am getting ##f_{n}(x_{n}) = n\left(1-\frac{n}{n+1}\right)^{n+1}##
does that still converge to ##\frac{1}{e}?##
  • #32
Wabbit,
No it doesn't, but what you're getting is incorrect - check your calculations again, you must have let a mistake slip by somewhere.
  • #33
<Snip>.
I don't understand, aren't you saying here that the series converges pointwise to ##0## on ##[0,1]## but ##f_n(x_n) \rightarrow 1/e ##. How is this possible?
  • #34
To state it in more general terms, if ## f_n\rightarrow f ## and ## x_n\rightarrow x ## we might expect to conclude that ## f_n(x_n)\rightarrow f(x) ## - and while it is easy to prove that this is a theorem if the convergence is uniform, the conclusion does not hold if it is only pointwise.
That sequence was built I imagine precisely to illustrate how, lacking uniform convergence or another suitable assumption, the diagonal sequence may converge to a limit which is not the pointwise limit. Another very similar one which makes this perhaps clearer is the sequence of piecewise linear functions with ##f_n(0)= f_n(1-\frac{2}{n})=0 ; f_n(1-\frac{1}{n})=1 ; f_n(1)=0 ## and linear interpolation between those points : for any given ## x ## the sequence ## f_n(x) ## is constant and equal to zero except for a finite number of terms, yet by definition ## f_n(x_n)=1 ## for ## x_n=1-\frac{1}{n} ## .
  • #35
One more comment : I suspect that for continuous functions on a compact set, the statement "##\forall (x_n)|x_n\rightarrow x, f_n(x_n)\rightarrow f(x)##" is actually equivalent to uniform convergence "## f_n\rightarrow_u f##".
FAQ: Show ##\{nx^{n}(1-x)\}_{n = 0}^{\infty}## converges uni
1. What is the formula for the sequence ##\{nx^{n}(1-x)\}_{n = 0}^{\infty}##?
The formula for the sequence is ##nx^{n}(1-x)##, where n is the index of the term in the sequence.
2. How do you determine if a sequence converges uniformly?
A sequence ##\{a_n\}## converges uniformly if for every ##\epsilon > 0##, there exists a positive integer N such that ##|a_n - L| < \epsilon## for all n ≥ N, where L is the limit of the sequence.
3. What is the limit of the sequence ##\{nx^{n}(1-x)\}_{n = 0}^{\infty}##?
The limit of the sequence is 0, as n approaches infinity and x is between 0 and 1.
4. Can a sequence converge uniformly without converging pointwise?
Yes, a sequence can converge uniformly without converging pointwise. This means that the limit of the sequence exists, but it is not the same as the pointwise limit.
5. How can you prove that a sequence converges uniformly?
To prove that a sequence ##\{a_n\}## converges uniformly, you must show that for every ##\epsilon > 0##, there exists a positive integer N such that ##|a_n - L| < \epsilon## for all n ≥ N, where L is the limit of the sequence. This can be done using the definition of uniform convergence and various convergence tests such as the Cauchy criterion or the Weierstrass M-test.
