Show that ## 168=3\cdot 7\cdot 8 ## divides ## a^{6}-1 ##
  • Thread starter Thread starter Math100
The discussion focuses on proving that if the greatest common divisor of a and 42 is 1, then 168 divides a^6 - 1. The proof utilizes Fermat's theorem to establish that a^6 is congruent to 1 modulo 2, 3, and 7. It also shows that a^2 is congruent to 1 modulo 8 by demonstrating that a, being odd, leads to a^2 having a specific form. The factorization of a^6 - 1 is mentioned but deemed unnecessary for the proof. Ultimately, the conclusion is that since 3, 7, and 8 are relatively prime, 168 indeed divides a^6 - 1 under the given conditions.
Math100
If ## gcd(a, 42)=1 ##, show that ## 168=3\cdot 7\cdot 8 ## divides ## a^{6}-1 ##.
None.
Proof:
Suppose ## gcd(a, 42)=1 ##.
Then ## 42=2\cdot 3\cdot 7 ## and ## gcd(a, 2)=gcd(a, 3)=gcd(a, 7)=1 ##.
Applying the Fermat's theorem produces:
## a\equiv 1\pmod {2}, a^{2}\equiv 1\pmod {3} ## and ## a^{6}\equiv 1\pmod {7} ##.
This means ## a^{6}=(a^{2})^{3}\equiv 1\pmod {3} ##.
Observe that ## a^{6}-1=(a^{3}-1)(a^{3}+1)=(a-1)(a+1)(a^{2}+a+1)(a^{2}-a+1) ##.
Since ## a ## is odd, it follows that ## a>0\implies a\geq 3 ##.
Now we have ## a^{2}\equiv 1\pmod {8}\implies (a^{2})^{3}\equiv 1^{3}\pmod {8}\implies a^{6}\equiv 1\pmod {8} ##.
Thus, ## 168\mid (a^{6}-1) ## because ## 3, 7, 8 ## are relatively prime to each other.
Therefore, if ## gcd(a, 42)=1 ##, then ## 168=3\cdot 7\cdot 8 ## divides ## a^{6}-1 ##.
Math100 said:
Homework Statement:: If ## gcd(a, 42)=1 ##, show that ## 168=3\cdot 7\cdot 8 ## divides ## a^{6}-1 ##.
Relevant Equations:: None.
Proof:
Right, but what did you use the factorization of ##a^6-1## for? Instead, you should have explained ##a^2\equiv 1\pmod{8}.## E.g. by ##(2k+1)^2=4k(k+1)+1## where either ##k## or ##k+1## is even.
Absolutely nothing. Now, I just realized that I shouldn't factor out ## a^{6}-1 ##, because like you mentioned, I didn't use this on anything in this proof. Also, for the ## a^{2}\equiv 1\pmod {8} ## part, are you saying that letting ## a=2k+1 ## where ## k=2m ## for some ## k\in\mathbb{Z} ## can help better explain where we got the ## a^{2}\equiv 1\pmod {8} ## part from?
Number theorists have it probably in mind: ##a\equiv 1\pmod{2}\Longrightarrow a^2\equiv 1\pmod{8}## but I had to use this additional line. From ##a\equiv 1\pmod{2}## we get ##a=2k+1## and ##a^2=4k(k+1)+1.## This shows ##a^2\equiv 1\pmod{8}## no matter whether ##k## is odd or even because ##\{k,k+1\}## always contains an even number.
I have to use this additional line, too, given the fact that I am not a number theorist. In fact, I got the ## a^{2}\equiv 1\pmod {8} ## part, mainly because ## a ## is odd and so ## a>0, a\geq 3 ##, that's why I plugged in ## a=3 ## and got ## a^{2}=9, a^{2}\equiv 1\pmod {8} ##, but I think this is vague, just as you mentioned above, I should have explained this. Thank you for the additional line.
