Show that 2^(1/3) + 3^(1/3) is irrational.
  • Thread starter jebodh
  • Tags
    Irrational
Thank you so much for the help!In summary, to show that 2^(1/3) + 3^(1/3) is irrational, we can construct an explicit polynomial with integer coefficients, f(x), such that f([x][/0]) = 0. By simplifying the expression x_0^3=5+\sqrt[3]{6}x_0, we can eliminate the final cube root and have an integer polynomial. This proves that f(x) has no rational roots, thus showing that 2^(1/3) + 3^(1/3) is irrational.
jebodh
Show that 2^(1/3) + 3^(1/3) is irrational. Hint: show that [x][/0] = 2^(1/3) + 3^(1/3) is algebraic by constructing an explicit polynomial f(x) with integer coefficients such that f([x][/0]) = 0. Then prove that f(x) has no rational roots.
Note:[x][/0] means x subscript zero
First I solved for x^3 and got 5+3{6^(1/3)[2^(1/3) + 3^(1/3)]}.
Then I did x^9=[x^3]^3=> (after some work I got=> 125(x^3) -500 + [2^(1/3) + 3^(1/3)]{15[6^(2/3)] + 162}
Do I cube the expression again, or I'm I missing something?
My question is what am I supposed to do with this term,
[2^(1/3) + 3^(1/3)]{15[6^(2/3)] + 162}?
Thanks,
Daniel
The hint suggests to find a polynomial with integer coefficients. You have the right idea cubing, but there's a little more.
You found [tex]x_0^3=5+\sqrt[3]{6}(\sqrt[3]{2}+\sqrt[3]{3})[/tex].
But you can simplify that even more, by substituting [tex]x_0[/tex] in for [tex]\sqrt[3]{2}+\sqrt[3]{3}[/tex], to get [tex]x_0^3=5+\sqrt[3]{6}x_0[/tex] Then try to get rid of the final cube root, and you have an integer polynomial.
Thanks, I'll try it now.
I can't believe I didn't do that.
FAQ: Show that 2^(1/3) + 3^(1/3) is irrational.
1. What does it mean for a number to be irrational?
An irrational number is a number that cannot be expressed as a ratio of two integers. In other words, it is a non-terminating, non-repeating decimal.
2. How do you prove that a number is irrational?
To prove that a number is irrational, you must show that it cannot be expressed as a ratio of two integers. This can be done through various mathematical techniques, such as proof by contradiction or proof by contrapositive.
3. What is 2^(1/3) + 3^(1/3)?
2^(1/3) + 3^(1/3) is the sum of the cube roots of 2 and 3, which can also be written as the cube root of 2 plus the cube root of 3.
4. Why is 2^(1/3) + 3^(1/3) considered irrational?
2^(1/3) + 3^(1/3) is considered irrational because it cannot be expressed as a ratio of two integers. This has been proven through mathematical techniques, such as showing that it is a non-terminating, non-repeating decimal.
5. Can you provide an example to illustrate why 2^(1/3) + 3^(1/3) is irrational?
One way to illustrate why 2^(1/3) + 3^(1/3) is irrational is to use the proof by contradiction method. Assume that 2^(1/3) + 3^(1/3) is rational and can be expressed as a ratio of two integers, a/b. Then, by squaring both sides, we get 2 + 3 + 2^(1/3)*3^(1/3) = a^2/b^2. However, we know that 2^(1/3)*3^(1/3) is irrational, and thus a^2/b^2 is irrational, which contradicts our assumption. Therefore, 2^(1/3) + 3^(1/3) must be irrational.
